Kx450f 2012 bogging - Office Equipment & Supplies
3 Suggested Answers
  • 3799 Answers
SOURCE: 2012 kx450f bikes cut out when accelorating
Check your fuel/air filter These will usually last about 2 years, but this will depend on how the machine is used. If you use the machine a lot off road you should be doing a yearly service approx every six months. Also make sure your fuel pump is running.
Posted on Apr 21, 2013
  • 7 Answers
SOURCE: engine cut out when accelerating
check your fluids maybe it over heated new engines tend to have bits of metal still in the block that breaks loose and is taken out via oild and fluid changes nescesary in the first few months of breaking in the engine. change the oil and see if that helps could it have been test drove alot?
Starts and idles fine runs half throttle when fuel is applied
Harry, dirty carb or injectors.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 06, 2016 | ATVs
I have a 2000 blazer. it idles fine but when i give it gas while driving it wants to choke out
Blazer bogs down while accelerating - Blazer Forum - Chevy Blazer ...
blazerforum.com > ... > 2nd Gen S-series (1995-2005) Tech
Jul 28, 2009 - Hello, I have a 1998 Blazer which bogs down when I accelerate. TheBlazer will pick up speed if I let up on the accelerator and gently press the ... Hard shift, then bogs down...lack of power
Mar 1, 2012
Bogs down when turning on heat
Dec 31, 2011
Won't accelerate after driving for awhile, please help.
May 29, 2011
Problems with bogging down and hesitation.
Sep 16, 2009
More results from blazerforum.com
Nov 29, 2015 | 00 2000 Chevrolet Blazer 4.3L V6 Ls Left...
2006 attic cat 400 runs great in 4x4 but when you hit the switch to 2x4 runs bad like it's booging down
'03 400 backfiring/bogging under throttle - ArcticChat.com ...
www.arcticchat.com > ... > ATV's > General ATV Discussion
Apr 3, 2007 - 7 posts - ‎7 authors The engine would only sputter and bog down, kinda like the choke was hung. ... I didn't remember the fan running, so I checked the fan fuse, but it was ... of the windings and cause a misfire, so bad that it would kill the bike. '07 F8 intermittent start and bog issue - ArcticChat.com
Dec 23, 2012
Arctic cat suzuki 700 efi wont start - ArcticChat.com ...
Apr 28, 2012
400 4x4 idles but bogs out when throttle pressed ...
Jun 29, 2011
cat is slowly dying
Oct 10, 2008
More results from www.arcticchat.com
Oct 21, 2015 | ATVs
2009 kx450f losing water and oil
If not leaking its the head gasket
Apr 30, 2013 | 2009 kawasaki KX450F
Apr 21, 2013 | Motorcycles
Engine cut out when accelerating
Apr 21, 2013 | kawasaki Motorcycles
2006 Kawasaki KX 450 F will not kick start
Hi, Stephencoish and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
14. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
15. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
16. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
17. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
18. Faulty neutral, clutch, kickstand safety switch.
19. Faulty fuel pump or fuse or relay.
20. A stuck bent or burnt valve.
21. Tilt sensor needs a reset.
22. Security system not disarming alarm needs a reset.
23. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2006 kx450f will not kick start
2009 KX450F Will Not Start Help
Kawasaki KX450F Service Manual
OEM Parts for Kawasaki
Kawasaki KX450F 2012 Owner Manual
Oct 12, 2017 | 2006 kawasaki KX 450 F
18 people viewed this question
jasbo
jasbo
