Question about Harmony Baby Armour Adjustable Booster Car Seat
How do you adjust the shoulder straps on a bebehut carseat
Cant figure out how straps go back on carseat since I washed it? its the brown and tan high back with tilt...omgoodness I cant believe I have done this please help!!!!!!
This isn't a product available in the UK so we're unable to assist with your enquiry. Could you let us know what country you're in so we can direct you to the appropriate customer care team?
Aug 04, 2012 | Safety 1st Baby Gear
I cant adjust the shoulder straps on my maxi cosi sps
Full directions on how to adjust the harness can be found in the user manual. For a replacement user manual go to www.maxi-cosi.com and select the model carseat you have, then download the user manual.
Feb 10, 2011 | Maxi-Cosi Priori
How can i make the headress go upto make the carseat bigger??
Good Evening
Take hold of the headrest and lean it forward (toward the front of the carseat) then you can slide it up and down to wherever the harness needs to be for the best fit for your child.
The shoulder straps should be no more than 1 inch above or below the childs shoulders when correctly adjusted.
Jan 04, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
I have a Cosco Juvenile car seat and my husbands car. In the back seat he has seat belts that are a combination shoulder and lap strap. How do you connect the car seat so that it is secure in the back...
you take the seat belt and put the lap strap thru the back of the carseat and click in in on the oher side pull tight and carseat is secure. the shoulder strap part doesnt effect the safety of the car seat at all
Sep 12, 2009 | Baby Gear
How do you raise the shoulder straps up to a higher level on the Britax Marathon carseat?
The straps must be undone from a claw on the underside of the car seat so you have to remove the whole thing from the car. The claw is designed to keep the straps in place and this it does very well but its position on the undercarraige leaves no room for your hands and makes it near impossible to manage.
Jun 13, 2009 | Britax Marathon
Trying to adjust the child seatbelt harness higher in the carseat
I located my instruction manual for this carseat. It instructed me to turn the carseat over & located on the bottom are two metal brackets that lock the seatbelt harness. You just have to detach each metal bracket & pull through the bottom slots of the carseat, readjust each seatbelt to whatever level is necessary & push back through the bottom of the seat to lock securely. Thanks anyway for your help!
Apr 09, 2009 | Evenflo Baby Gear
Shoulder straps
There should be metal hooks on the backside that hook onto the loops at the end of the shoulder straps. They will definately be metal so should be easy to spot against the plastic back of the car seat. They usually are sort of rectangular and have one side that has a 'lip' so the straps aren't supposed to just slip off. (Though I can imagine the possiblity of this when the belt is not stretched as it is during use) Refer to your manual if you cannot find them. If you no longer have the manual, you should be able to locate one for downloading or viewing PDF file at the manufacturers website. Hope this helps! :)
Jul 25, 2008 | Graco ComfortSport 8431
Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Jul 31, 2007 | Evenflo Embrace - Rainforest
Can't remove carseat cover
There is a trick to this. All the straps are kinda connected together. The main harness is one piece, a clever clip on each of the lap section. (one on each side) needs to be removed to allow the belt to slide through the seat and cover openings. Once here the strap needs to go through the actual seatbelt buckle. Once the buckles are off you can pull the harness through the shoulder opening. The note to take here is that the harness runs through a loop on the adjuster belt (a narrower belt that runs from the back of the chair under the it to and through the adjusting fastener) Once through the loop you can pull the main harness strap free from the chair. Now the next part, depress the release clip of the adjuster and with the other hand pull this belt free from adjuster. It may require a bit of two handed work as belt nears the end. You should now have a wide belt, a narrow belt, 2x clips and 2x harness buckles. All you need to do now is remove the adjuster which usually requires the manipulation of a metal 'B' buckle which is sewn into the loop to be twisted sideways to allow it to pass through the opening. You are home free now. The cover should be elasticated around the edging and easily removed for washing.(you can also put the straps in too) Now is also a good time to just give the actual seat a good clean too. Refitting is reversal of removal. However REMEMBER and NOTE the way clips,buckles and which openings the straps went through when removing. There are usually a couple. Mark the items with a marker if you think you'll forget. On refitting you might want to put it to the next one up. (as a child grows ie. the shoulder straps should be above the shoulders when the child is seated, equally important is they must be the same on both sides.) I think there might be a couple of slots for the adjuster strap. You might want to move that one out too. Have your child seated in the chair before you start the reassembly and mark out the openings the staps need to pass through which would be most comfortable for the him/her. Good Luck.
May 29, 2007 | Evenflo Victory 5 Comfort Touch
Cosco 5-point omega carseat
ok I had such a hard time with this, i looked on the internet for hours and found NOTHING!! haha so i went to babies r us and checked out a similar one so here it is.
first the strap goes on the bottom, pull them even and the add the buckle, plastic buckle thing, and the other thing soft thing. then put the strap through the back of the seat (you should have two ends) not the must go OVER the adjusts! now take the metal piece that adjust the length and pull it long enough for it to reach the two straps and hook them up!! haha if this isnt good enough go to a store that carries the alpha omega elite car seats and check it out! GOOD LUCK!!
May 10, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Harmony Baby Armour Adjustable Booster Car Seat Logo
69 people viewed this question
Top Harmony Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Harmony Baby Gear Expert? Answer questions, earn points and help others
