Question about Health & Beauty
I have a rma shoprider model TE-SL7-4, when I turn it on there is a continuous beeping sound and it's not the freewheel lever any suggestions? Many thanks
2 Suggested Answers
SOURCE: my shoprider dasher just beeps
we just bought a shoprider monaco,after i cleaned it it did same thing just kept beeping,i found moving the free wheeling lever under back bumper a few times cleared it.Lever makes contact with a micro switch,on motor.
Hope this helps
Posted on Sep 10, 2009
My shoprider scooter lights up when key is turned on but cannot get any forward or reverse movement...any suggestions please
Make sure the freewheel lever is engaged. The connections on the controller may be loose or the large connections where the front and rear separate aren't making a good connection.
Apr 15, 2017 | Shoprider Health & Beauty
I have a shoprider dulux and all lights work all fuses work but scooter wont move forward or back checked the free roll lever and break they both good and in right position please help
Hi just check to c if U have freewheel lever in correct position if U can push the scooter it's in freewheel ,::::::: push the lever the other way so it locks into gear check to c if it's locking in gear :::: if U can't push it it's in the correct position,.., Cheers
Nov 22, 2016 | Shoprider Health & Beauty
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
Constant beeping when turned
The freewheel lever isn't re-engaged properly. Try moving the lever to "free" then back to "drive" again. The lever moves a small micro-switch.
Apr 02, 2014 | Electric Mobility Health & Beauty
My echo 3 scooter beeps as soon as I turn on the power. It shows a full charge, but there is no response when I push the lever. The brake is released. The horn works.
Boy I hate working on scooters too many things can go wrong to make them not work. First make sure you are not in freewheel Make sure the lever at the rear of the scooter is in drive position. and you can't push the scooter easily without powering it up. If its not in freewheel then the problem could be a throttle pot problem or a speed pot problem or even a motor problem and there is no way I can troubleshoot your problem in this format. I would suggest that you have your provider check it or if Medicare paid for it have a repair service fix it for you. Sorry can't really give you a precise answer on whats wrong Good Luck Hope this helps
Nov 19, 2010 | Shoprider Echo 3 Wheel Scooter
Constant beeping, won't run
The beeping on shopriders usually means that the Main Control Box is faulty. It may also be caused by the Throttle Pot being out of neutral. This is a common promlem on this model of scooter as they use a Plastic throttle control lever instead of a metal one. Unfortunately, the plastic one's sometimes slip round slightly causing the above problem. Throttle pots can be very difficult to set to neutral without a multimeter so may be best left to you local dealer.
Jul 01, 2010 | Echo 3 TE SL7 3 New Electric Scooter by...
Shoprider sovereign when switching on and pressing reverse scooter will not move but reverse bleeper sounds nor will scooter move forwards. switch off and on again and on then works correctly
If the freewheel lever has been operated while key is in on position the scooter will not operate until key is turned off and then on again, make sure freewheel lever is in drive position. hope this helps.
Jun 29, 2009 | Kitchen Appliances - Others
Not running - full battery
hi look up www.americanmobilityscooters.com in Jacksonville FI 32211 ...Cheers
Apr 05, 2017 | Echo 3 TE SL7 3 New Electric Scooter by...
Health & Beauty Logo
46 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
