Question about Grace Digital Tape 2 USB Dual Cassette Deck
I have a TAPE2USB 11 with no direction / I'm in need of directions for this unit
Where am I suppose to vote? My address is 7824 Daniel Dr N Richland TX 76182.
We are in California but here is what is listed.
645 Grapevine Highway Hurst, TX 76054 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 B 828 West Harwood Road Hurst, TX 76054 Directions Closed · Opens 7 AM MonHours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Last day to vote early at this location is Nov 3 C 5350 Basswood Boulevard Fort Worth, TX 76137 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 100 Main Street Colleyville, TX 76034 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 6801 Glenview Drive North Richland Hills, TX 76180 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 1100 Bear Creek Parkway Keller, TX 76248 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 700 Mary Drive Hurst, TX 76053 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 2424 Forest Ridge Drive Bedford, TX 76021 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 3201 Friendly Lane Haltom City, TX 76117 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 201 North Ector Drive Euless, TX 76039 Directions Closed · Opens 8 AM Fri
Oct 27, 2016 | Cars & Trucks
How do you recharge a Motor Trend Jump starter and air compressor
Should have been a patch cord that connects directly to the unit and to 110 volt plug for charging the unit back up. There's a built in convertor that does the re-charge. Find that cord or purchase one from where you got the unit.
Jun 28, 2014 | Power Center Jumpstart 11-411
Lionel f7 only runs in reverse
Have you checked to see if the direction switch is on? Most Lionel locomotives can be set to run in one direction by turning the direction sequencing off. This is true for the newer electronic direction circuits and the older electromechanical E-units. Sometimes the direction units fail and the locomotive will only go in one direction or sits in neutral. If that is the case, the direction unit will need to be serviced (mechanical type) or replaced (electronic type). Go to Lionel.com for additional information and help.
Mar 03, 2014 | Lionel Trains Santa Fe Flyer Freight Train...
Direct x 8.1 cd key not found
I would prefer you to download direct x 11 from microsoft website...Just search for direct x 11 download and click on top result... No need to enter any key, just install setup and enjoy...!!!
Dec 21, 2013 | Blizzard Entertainment WarCraft III: The...
Hi I cant install direct 3d free download
Try downloading Direct 3D from http://www.blogsdna.com/2764/download-windows-7-direct3d-11-directx-11.htm (The web-installer version.)
Make sure your computer's hardware is able to handle the games or other software that require it.
May 04, 2011 | Computers & Internet
The alternator keeps spinning even ater the engine has stopped for a few seconds
Part Number: 12241 Weight: 14.35 lbs Warranty: Limited Lifetime Notes: 100 AmpPremium reman Unit Manufacturer:
Amperage: 100 A. Pulley Type: 6S clutch pulley Fan: Internal Regulator: Internal Regulator Plug Clocking: 11:30 Notes: This unit is supplied with an OE style pulley clutch which rotates freely in one direction only. Trying to force the pulley to spin in the opposite direction will damage the unit and void your warranty.It has a clutch pulley
Jan 03, 2011 | 2000 Mazda MPV
Got the Tape2USB for christmas and cannot get it to successfully record to computer. Followed installation directions closely. When I want to record, I press [on Tape2USB] 'Play'. Then, I press [on MAC]...
I'm not familliar with this device but from the ERROR it spits out you seam to have a configuration problem, since it is a TAPE wich is 44 Khz SAMPLE RATE, check the sampling rate settings it might be to high or to low
Hope this helps!
Dec 31, 2010 | Grace Digital Tape 2 USB Dual Cassette...
Hello how to enable direct x features please help me
You simply install direct X, It should come with the media, You have to have a card that supports the direct x featured and to use feature direct X 10 you need vista, for direct X 11 you need windows 7. I do not think there is anything requiring 11 though.Check your graphics card support and make sure you have installed at least direct x 9c redistribute, It should be in the installers on your disk.
Mar 08, 2010 | Ubi Soft Entertainment 02B Game PC...
Text to speech voice breaks up when giving directions
Download software update 4.80 released 5/11/2009, fixed this problem on my Gramin 750
Jan 26, 2009 | Garmin nuvi 750 GPS Receiver
Grace Digital Tape 2 USB Dual Cassette Deck Logo
27 people viewed this question
Top Grace Digital Audio Players & Recorders Experts
John
John
Jim
joel maureal
Are you a Grace Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
