Question about Whirlpool GFG461LVS Stainless Steel Gas Range
Whirlpool gfg461lvs 1 oven pilot light - Whirlpool GFG461LVS Stainless Steel Gas Range
Oven quits heating at times
More than likely that you have a break in the continuity of the oven's heating element. Take it out and connect a volt meter to either side of the connections where the element plugs in. If it's OK, then you simply need to replace the element. Not a hard job. . .
Dec 21, 2015 | Whirlpool GFG461LVS Stainless Steel Gas...
Whirlpool gfg461lvs broiler won't light
Hello. How old is the range? The broiler ignitor might be worn out. The part number you might need is 8054129. The ignitor for the bake is 9758079. I hope this helps you.
Sep 12, 2015 | Whirlpool GFG461LVS Stainless Steel Gas...
Where is the Pilot for my whirlpool oven
If you have a pilot light, it's in the oven section you take the bottom plate off with the 2 screws holding it on. It's going to be in the back by the burner valves. Most whirlpools don't carry pilot lights.
Nov 28, 2013 | Whirlpool Stove / Oven / Range Pilot...
On my whirlpool gas range only 1 burner out of 5 will ignite. oven light works, oven ignites. only 3 months old and worked fine until now.
Most often when cleaning, soapis left behind and obstructs the flow of ignition gas normally directed at the exact point of the spark. Check this area and use a small wire brush to clean these area of the burners that do nto work. Let us know if this helps. Eric Campion
May 19, 2012 | Whirlpool GFG461LVS Stainless Steel Gas...
Where is the oven pilot light ?
Most modern ranges don't use pilot lights at all; if your burners are lit by high voltage spark, the oven will use either that or a 'surface igniter' to turn on the oven. Even though pilot lights don't use much, they still use some and this would add to your bill (if you have one-we have free gas).
Oct 07, 2009 | Whirlpool SF357 Gas Kitchen Range
Oven won't light
there is the oven ignitor nest to the oven burner it's an electric pilot, it's about 4 inches long by 1 inch thick, it needs to be replace.
Dec 08, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool Super Capacity 465 Gas-pilot light won't stay lit
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Oct 01, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool GFG461LVS Stainless Steel Gas Range Logo
29 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
