Cscapi.dll is either not designed to run on Windows
2 Suggested Answers
  • 388 Answers
SOURCE: sensapi.dll error
How to Fix Sensapi.dll ErrorsImportant: Do not download sensapi.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of sensapi.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the sensapi.dll error.
  1. Restore sensapi.dll from the Recycle Bin. The easiest possible cause of a "missing" sensapi.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted sensapi.dll but you've already emptied the Recycle Bin, you may be able to recover sensapi.dll with a free file recovery program.
    Important: Recovering a deleted copy of sensapi.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some sensapi.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the sensapi.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the sensapi.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the sensapi.dll file. If the sensapi.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the sensapi.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to sensapi.dll. If, for example, you're receiving a "The file sensapi.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The sensapi.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if sensapi.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the sensapi.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The sensapi.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause sensapi.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual sensapi.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair sensapi.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid sensapi.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the sensapi.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the sensapi.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any sensapi.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The sensapi.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 7, Windows Vista, Windows XP, and Windows 2000.
Posted on Feb 11, 2012
Sensapi.dll error
Applies To
Feb 11, 2012 | HP Pavilion Dv9910us Notebook PC
An internal application error has occurred
Method 1: Reregister Jscript.dll and Vbscript.dll
  • Click Start, and then click Run.
  • In the Open box, type regsvr32 jscript.dll, and then click OK.
  • Click OK.
  • In the Open box, type regsvr32 vbscript.dll, and then click OK.
  • Click OK.
If either of the files do not register as expected, or if you receive an error message, the system file may be missing or damaged. To extract the missing file in Microsoft Windows XP, follow these steps:
  • In the Open box, type msconfig, and then click OK.
  • Click Expand File.
  • In the File to restore box, type the name of the file that you want to restore.
  • In the Restore from box, type the path of the Windows XP .cab file where you want to restore the file, or
    click Browse From to locate the Windows XP .cab file.
    Note The Windows XP .cab files are stored in the I386 folder on the Windows XP CD.
  • In the Save file in box, type the path where you want to extract the new file, or click Browse To to locate the folder that you want.
  • Click Expand.
  • In the System Configuration Utility dialog box, click OK. If you are prompted to restart the computer, click Restart.
Open a dialog box that previously experienced the issue that is described in the "Symptoms" section of this article. If the issue recurs, go to the next method.
Jun 14, 2011 | Microsoft Windows Media Player
I can't change my background
Hi
Download shell32.dll from the following link, and then type "regsvr32 shell32.dll and press Enter" at Run Command in Windows 7.
When you click the following link a page will open, Click Download shell32.dll to download the file.
http://www.dll-download-system.com/dlls-s-/shell32.dll.html
If you face any issue, please let me know.
This solution is absolutely FREE, please rate and give your feedback.
May 10, 2010 | ASUS P5PE-VM Motherboard
Download icuin36.dll. The computer tell me that It can't find this file and I should to get it. Could you please tell me where can I get it? And very often my computer close down some programs because...
David
Try this first Click on the Start Button
Go to Run and click on it
In the Run box type the following:
regsvr32 icuin36.dll
If it is successful it will tell you and the problem should be fixed
If not try this download
http://kromann.info/icu/icuin36.dll
DLL (Dynamic Linked Library) Files:
To download and install a DLL file, you will first need to download the DLL file and register it on your computer.
Steps:
  1. Download the DLL file using the download link on this page and save the file to one of the folders as seen in step 3. .EXE files do not need to be manually registered.
  2. Backup the old version of the DLL file.
  3. Click Start > Run and type in the following command:
Windows 95, 98, or Me:
regsvr32 \windows\system\icuin36.dll
Windows NT or 2000:
regsvr32 \WINNT\system32\icuin36.dll
Windows XP or Vista or Windows 7:
regsvr32 \windows\system32\
icuin36.dll
Oct 14, 2009 | Computers & Internet
Cannot use my pictures folder in windows XP, error reads Uxcore.d
Try re-installing uxcore.dll file.
To re-install UXCore.dll
Just follow this repair link (http://www.corruptedfilerepair.com/File-Information/UXCore.dll-Windows-Live-Client-UX-Microsoft-Corporation.asp) and download the file named UXcore.dll
Steps:
1. Download the DLL file from the download link on this page and save the file to one of the folders as seen in step 3. .EXE files do not need to be manually registered.
regsvr32 \windows\system\UXCore.dll
Windows NT or 2000:
regsvr32 \WINNT\system32\UXCore.dll
regsvr32 \windows\system32\UXCore.dll
Download File UXCore.dll
EXE (Executable) Files:
Steps:
1. Download the file to a folder on your computer
2. Scan the .EXE file using an Anti-Virus Scanner.
3. Run the .EXE file by double-clicking the file
ZIP/RAR Archives:
You will need to uncompress the files in the archive using WinRAR or WinZip first.
Nore : Default Location - c:\program files\windows live\installer\uxcore.dll
Jul 17, 2009 | Microsoft Windows XP Home Edition
Wmp 11 not working tried reinstallation and microsoft fix it
Click Start, click Accessories, the right click on Command Prompt and choose "run as administrator", then type regsvr32 jscript.dll, and then hit enter.
2. Type regsvr32 vbscript.dll then hit enter.
3. Now type exit and hit enter. Now try media player .
Mar 30, 2009 | Microsoft Windows Media Player
Cannot get easycap usb to be recognised
the mmci.dll file may be corrupted. go to the following link and down load the dll file.
http://www.dlldll.com/mmci.dll_download.html
it should work with correct dll file
Feb 23, 2009 | Ulead Videostudio 8 for PC
Videos
try this works for me
Fixing Internet Explorer Javascript Links
Sometimes in IE when you try to open links that open in new windows, they don't open. At the bottom left of the IE window you will see a yellow triangle which indicates its a Javascript problem.
  1. Start » Run » Type regsvr32 /s URLMON.dll
  2. Then do the same but change the DLL names to the following:
    scrrun.dll
    Msxml.dll
    Mshtml.dll
    Shdocvw.dll
    Browseui.dll
    Msjava.dll
    Actprxy.dll
    Jscript.dll
    Vbscript.dll
    oleaut32.dll
  3. Restart IE and your links should be fine.
  4. Alternatively you can copy this in to a text file and save it as a batch file (.bat file)
    regsvr32 /s scrrun.dll
    regsvr32 /s Msxml.dll
    regsvr32 /s Mshtml.dll
    regsvr32 /s Shdocvw.dll
    regsvr32 /s Browseui.dll
    regsvr32 /s Msjava.dll
    regsvr32 /s Actprxy.dll
    regsvr32 /s Jscript.dll
    regsvr32 /s Vbscript.dll
    regsvr32 /s oleaut32.dll
  5. This will re-register all the DLL files. All of the above are used by IE.
Oct 11, 2008 | YouTube Videos
Shell32.dll
Try running RUN and type regsvr32.exe /i shell32.dll.
This actually fixes the shell32.dll and installs it again.
RegSvr32.exe has the following command-line options:
Regsvr32 [/u] [/n] [/i[:cmdline]] dllname
/u - Unregister server
/i - Call DllInstall passing it optional [cmdline] (/i /u calls dll uninstall)
/n - do not call DllRegisterServer (must be used with /i)
/s  Silent (added with Windows XP and Windows Vista)
Aug 20, 2008 | Microsoft Windows 98 for PC
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
