Question about Water Heaters
The blue box in my Airing cupboard is making a clicking sound, im sure this regualtes the heating for our boiler and now the heating or water will not get hot.
kma836
  • 7 Answers
SOURCE: boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Posted on Oct 18, 2008
  • 659 Answers
SOURCE: hot water boiler will not ignite
Check all your limit switches on this unit. One of them is either tripped or bad.
Posted on Apr 07, 2009
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
Posted on Jul 12, 2009
  • 150 Answers
SOURCE: alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Posted on Sep 02, 2009
mrhotandcold
  • 248 Answers
SOURCE: Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Posted on Oct 11, 2009
How to fix my Worcester green star ri boiler?
The gurgling sound sounds like you have gotten air into the system. Try purging the air out at the bleeder valves. Also check and make sure that your water inlet is working.
May 29, 2016 | Water Water Heaters
Hello i have problem with my boiler mate 2000,when heating is swithch on , boiler on the kitchen still flashing with green lights (reset) im not sure how they fixted this problem all radiators ok ,hot
Hello Wojtek!
Over here in the colonies, we don't know from Boiler Mates, and I'm sure you have already discovered the same documents I foumd. The word "fiddly" came up in the second link and while we don't use that term often on this side of the pond, it definitely sounds pejorative.
Unfortunately, as we say over here, you may be "in for it".
Other than a reset, have you tried a "hard" reset by pulling the power? How about control/alt/delete ???
OK, now I'm getting silly.
All the best
http://www.gasapplianceguide.co.uk/Gledhill%20Boilermate%20explained.htm
http://www.gledhill-response.net/documents/boilermater2000switch_user.pdf
Dec 06, 2014 | Water Water Heaters
The receiver box on my central heating boiler got wet and the boier has gone off,how do i get it working again
Yes make sure that new controls wireing config. is comatable with old one ,same number of tie points some may have more but still work ,universal controller.
Feb 24, 2013 | Honeywell AQ2504B2 Aquatrol Boiler Control...
Ariston euro-combi boiler not giving hot water
odd noise like popping or singeing fire....clicking noises.....sounds like you have a water leak putting out the pilot.......or your thermo coupling is bad....or the noise is the tank full of calcium buildup and that will make noises when the burner is on
Jan 19, 2013 | Water Heaters
Central heating and hot water have suddenly stopped working
not an engineer but maybe a heating compant,, it sounds like you have a relay that has gone bad, you have what we call a winter summer system your domestic water comes from a tank inside the boiler, you might want to think about splitting the system to save you some money in the long run, seperate the water heater from the boiler so you only heat up in the winter, right now you are heating the system that heats your house to get 30 or 40 gals of domestic hot water, it would cost you less by seperating them
May 17, 2009 | Water Heaters
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
May 03, 2009 | Bosch & Power Vent Water Heater
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
Non i;n working boiler
Did you put automatic vent plugs on this boiler?This help stop from having air locks.I would try bleeding the high pipe to see if any air come out.The other thing I would check is the valve that out for the pump to pump water around.
Mar 17, 2009 | Water Heaters
Combi Boiler - Hot water pressure low
the coil inside got clogged
Dec 22, 2008 | Water Heaters
Locating pump on Baxi Back Boiler
hi this problem sounds like a pump problem. now if its not in the airing cupboard, sometimes they can be besides the boiler in a cupboard or under the floor where the boiler is sited, or boxed in in a dummy casing either side of the boiler/fire unit.
i suspectthatthe pump is stuck & needs releasing or worse case scenario a new unit fitted.
The reason you mentioned about frequently getting air in the system is condusive of sludge build up or the pipe-work configuration is not installed correctly giving rise to air being drawn into the system & posing future probs such as component failure.
If the pump is sited under the floor by the boiler it is at risk of collecting sludge as its at the lowest point in the system.
Recommendations re-site the pump if possible & look to have the system power flushed, to assist the life expectancy of the system
Kindly
Richie
Dec 02, 2008 | Water Heaters
Water Heaters Logo
22 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
