Question about Sewing Machines
How do you properly thread a Juki TL-2200QVP?
yalmer
  • 549 Answers
SOURCE: threading a juki ddl 5530
Go to this link and you will find how to thread your machine.
Posted on Apr 02, 2008
rylee_smith
  • 8619 Answers
SOURCE: my Juki DL 5555 won't pick up bobbin thread
It is possible that you have the bobbin in backwards. Try inserting the bobbin so that the thread pulls in the opposite direction than it currently does. Also, sometimes you have to really push the bobbin case in to make sure it snaps into place. Other than that, you may have a dull needle...try replacing it, or it just may need an overhaul.
Posted on Jan 30, 2009
Mimito7
  • 128 Answers
SOURCE: thread breaks
First, change the needle, second, set the tension 3-5 if it only goes to 8. Next, unthread the machine with new thread and be very careful to make sure the thread is in the tension wheel.
Posted on Apr 19, 2009
  • 14 Answers
SOURCE: Juki TL-98QE thread comes out of needle, won't pull up bobbin
It can be many things but first make sure the needle is in correctly, follow the manual to be sure, if it still does not pick up the bobbin thread you may want to bring it to a repairman to see if it is out of timing.
Posted on Jul 07, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: One of the thread tension plates is loose on my
Hi there 1st of all i like to say please change the rusti tension plates, otherwise its not moving well & the boobin does not follow the alinment. For humidity control i suggest you fix an air condition system in your working room & make the place clean & dry. Thanks & waiting for your feedback.
Posted on Feb 18, 2010
I have a Juki TL-98Q The thread cutter and the needle up down button don't work. How can I fix them?
Has a piece of broken needle or chunk of thread jammed into the blades and are not letting them move? If there was a big time thread jam it can actually break one of your blades and you will have to go to a repair man and have the blade replaced.
Jan 09, 2016 | Juki TL-98Q
How do I thread a juki tl 98q sewing maching
Its on page 17 of the User manual which can be found at
http://www.manualslib.com/manual/522990/Juki-Tl-98q.html?page=17#manual
Feb 28, 2015 | Juki Sewing Machines
Service manual is there one to download? juki tl
Yes, I think you just go to the website. Although I have one but it does not help much with thread and needle breakage except that the hook and loop probably need to be adjusted by a pro.
Aug 05, 2013 | Sewing Machines
I have lost the manual and i dont remember how to thread a bobbin. Pleas help me and thank you!
Juki TL-98Q
Loading the bobbin into the bobbin case:
Snap in the bobbin case latch, and put the bobbin into the bobbin case so that the bobbin runs clockwise.
Passing the thread through the **** of the bobbin case, continue passing it under the thread tension spring, and pull out the thread open end about 10 cm from the bobbin case.
Insert the bobbin case fully into the hook, and close the bobbin case latch.
You can obtain a copy of the manual in pdf format for free at:
http://www.juki.co.jp/household_en/pism/img/tl98q/download/98qim.pdf
Jul 29, 2010 | Juki TL-98Q
I having trouble putting my bobbin in my Juki TL 98E. I can not get my bobbin thread to come up because of this. How does this bobbin go in properly?
Well you could one or two make sure that the bobbin is set correctly or make sure that the parts is not bent or out of place this would make the bobbin not work propery. Ok
Dec 15, 2009 | Juki TL-98Q
Juki TL98Q needle thread breakage
your bobbin it is not in his right position, quit tightin your tension.
Sep 29, 2009 | Juki TL-98Q
Jul 06, 2009 | Juki TL-98Q
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
