Question about Dryers
Whirlpool lte6234dq5 Dryer does not turn off.
Whirlpool model # lte6234dq5 Dryer does not turn off.
Can this only be the timer assembly or something else?
  • Anonymous Mar 16, 2014
    how to replace timer on whirlpool dryer model LEQ9508LW0
  • 43 Answers
Could also be centrifugal switch on motor.
Posted on Apr 25, 2009
  • Mathew Johnstone Apr 25, 2009
My Whirlpool LEB6300PWO will randomly not start, or will start but only run briefly then stop. I know these types of problems are not usually related to the timer, but we have found that by either lightly...
Hello, we are sorry to hear that you are having this problem with the Dryer. We would recommend having a certified technician out to take a look at the Dryer and give a proper diagnosis. If you would like further assistance you can reach out to us with your name, phone number, address, model/serial number and the date on which you purchased the Dryer to Whirlpool_Reviews@Whirlpool.com.
Apr 17, 2017 | Whirlpool LEB6300 Electric Dryer
My Whirlpool electric dryer does not shut off when a load is done. The door must remain open in order for the dryer to stop. Other than that, the dryer works perfectly. Is it a switch or the timer or...
Pull the dryer out from the wall and take the vent hose OFF it is in the back, and then try it on auto-dry with no clothes in it and see if it runs through fine if it does not turn off then a new timer should fix it. Good Luck Tim. here is a website that will help click on timer motor, or you can use the virtual repairman:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 23, 2010 | Whirlpool Dryers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Our whirlpool 6th sense dryer model awz3413 will not turn on
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 21, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool electric dryer (Model # LER4634DQO). Dryer won't come on when we push the start button.
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
4. Timer
Jul 08, 2009 | Whirlpool Dryers
Whirlpool dryer won't heat
Ended up replacing the solenoids and the burner ignited, flame stayed on. Problem appears to be solved. Thanks for your help and posting.
Jan 03, 2009 | Whirlpool LGR7646E Dryer
My whirlpool clothes dryer will not start.
Hello Rick,
Use this link to get information for your dryer.. it should provide you with everything you need. Get back to me if you are still having problems..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Nov 28, 2008 | Whirlpool Dryers
I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T...
Hello dacarle,
Welcome,
You said, I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T START.
Please send me the model number so i can check out the problem.
Waiting your response
Huuum
Oct 15, 2008 | Whirlpool Dryers
Dryer doesn't get hot or turn off.
yes very possible timer but my guess on the times i seen the problem would be the heating element are the thermo fuse on the elemnt canister when the heater does not come on the timer will not move ck the heater and the fuses on the heater canister it will fix your problem
Feb 28, 2008 | Whirlpool LER4600 Electric Dryer
Dryers Logo
225 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
