Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
How do you change the water filter
I have an admiral side by side fridge freezer but have lost the manual. I want to change the water filter which is located under the freezer door.
It would appear that you should unscrew it out but it wont turn. Is there some mechanism to unlock it. In any case how do I do it.
  • 77 Answers
My experience with these is to push in and turn. Once it is turned, then pull. Good luck.
Posted on Apr 23, 2009
Where is the water filter and how do i change it
Filter should be located on the bak of the fridge or in the back of the fridge. My guess is that it's the water fill solonoid that isn't working or the ice level control is thinking the bin is full. I would look for the ice level sensor and give it a cleaning or replace it
Sep 06, 2012 | Admiral 26 cu. ft. Side-By-Side...
Have moved into new house with Admiral freezer/fridge/icemaker. Leaks water onto floor from time to time under freezer. Ice maker not connected to water supply so not that.ANY SUGGESTIONS?
Defrost drain is clogged causing this problem. Clear the dfrost drain and pan from inside the freezer section by removeing the freezer back cover plate and you will see from there. No extra parts required just patience.
Feb 01, 2010 | Admiral 26 cu. ft. Side-By-Side...
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral GC 2027 HNKBS
Hi i had the same problem, if you ring Maytag on 08444990101 they are the uk supplier for admiral fridge freezers. hope this helps
Mar 29, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Can't find the water filter on my admiral refrigerator
You should have a filter in one of two places the back of the fridge or under your sink
Feb 08, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water Filter
Open the fridge site, look up at the top right corner, half way to the back, you'll see the filter laying horizontally against the top of the fridge.
Push a button with the arrow to pull down the cover, you'll see the filter.
Twist the filter counter clockwise to remove it. My filter name is Puriclean II. Yours could be different.
Feb 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
The water input to the water filter is leaking - admiral model GC2224GEKB
my water filter water line is leaking from the bottom in the back of my refrigerater. How can i get to it to repair it.
Aug 19, 2008 | Admiral 26 cu. ft. Side-By-Side...
Problem with fridge ice maker
assuming the freezer is cold enough and that you have a valid water supply hooked up, either the icemaker is bad or the water valve is bad, best idea is to replace both.
Mar 30, 2008 | Admiral 26 cu. ft. Side-By-Side...
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
240 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jdthefixer
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
