Question about Apex Digital AT3208S 32" TV
Remote ck5g c1
How do I make the display on the tv smaller? The sides get cut off because the display is too large.
3 Suggested Answers
SOURCE: Finding a code
What is the model number of the Apex TV you are using this remote for?
The CK5G-C1 remote was supplied only with model AT3208S TV. It will require no code when used with that model. If trying to use it with any other model TV, you can try the other Apex TV codes found in the AT3208s user's manual that can be found in .pdf format at : http://www.apexdigitalinc.com/manual/AT3208S.pdf
Let me know if this helps, or I can be of further help.
In any case, good luck!
Posted on Oct 25, 2007
SOURCE: remote codes
Here is the PDF Owner's Manual:
Posted on Nov 14, 2008
Will apex ck5g-c1 remote control program to rca dolby digital analog pass through analog converter stb7766c
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Feb 20, 2016 | RCA Televison & Video
How do i remove key symbol onpicture of TV
The TV is locked. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given.
Oct 02, 2014 | Televison & Video
My tv will turn on but no picture of sound will show. The screen is completely black. When I press the power button on the remote the standby light on the tv blinks red twice then a smaller than usual...
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
I hope this will help in solving the problem....
Jun 09, 2011 | LG 42LG30 42 in. LCD HDTV
How do I change the format on the screen to fit my TV, the format is too large and the picture is getting cut off on both sides
U using the tv original remote wright?Yes.Check ur tv remote control for a button like View Mode,Aspect Ratio,Picture Zoom,P.Size.Pushes one of these buttons to ajust the tv picture screen sizes.
Mar 25, 2011 | Televison & Video
Picture is cut off on sides but not top and bottom. The display channel (default 2) is cut off on the side to give you an idea. (purchased it new around 1998-1999).
With TV powered off, use remote control to successively hit DISPLAY, 5, sound volume +, and POWER all within a second of each other. This takes you to the Service Adjust Mode and the first thing that appears is the Horizontal Size Adjustment "HSIZ". Press numbers 3 or 6 to make the picture larger or smaller. Other things can be adjusted by using numbers 1 or 4 to go through the list but you could really screw up your TV so don't do anything unless you are sure about it. When you're finished hit MUTING and then ENTER to save the changes.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Check fan # 2
Samsung Consumer LCD tv's do not have fans except on the higher end models. The Commercial models do. Yours is a Consumer model. I suspect that you have a DLP tv. In that case replace the Lamp Fan. It is the Larger of the three fans. With the rear cover off, you will see a Blue switch lever on the lower right side of the tv. Hold it in a up position and turn "on" the set with your tv remote. Then look for any fan that is not running. Then order that fan. there is a large fan that cools the Lamp. The other fans are of the same smaller size and one cools the DND chip and the other cools the Ballast.
Jul 04, 2009 | Samsung Televison & Video
Finding a code
Oct 22, 2007 | Apex Digital PF3220 32" TV
The picture is too large for the screen
If you have a cable or satellite HD box see if there is a ASPECT button or look for an aspect/picture size buttn on your TV's remote control.
May 06, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Apex Digital AT3208S 32" TV Logo
16 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
