Question about Konica Minolta magicolor 2480 MF All-In-One Laser Printer
WILL NOT PRINT ANYTHING OR COPY. IT WILL SCAN THE DISPLAY STATES: CAUTION MACHINE TROUBLE PLEASE POWER CYCLE (18H)
  • 82 Answers
Check fuser unit. Fuser does not reach the cpecified temperature within specified time, or will be low mains voltage...
Posted on Jul 16, 2009
What is18h code on gltf2940es0?
Thank you for your post, Jeff Duvall!
I see that your Frigidaire washer is displaying an error code of "18h". However, it appears "18h" is an invalid error code. In order to clear any false error codes, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for approximately ten minutes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "18h". I look forward to assisting you. -Matt
Nov 09, 2014 | Frigidaire Washing Machines
Error light flashes screen reads caution machine trouble than change to service call 101 h
Scanner motor malfunction, check the scanner lock switch, normal use when moving the machine so scanner does not break, or you have a bad scanner, which is located under the big glass with the very bright light that comes on when you scan or make a copy..
As for the paper check to ensure you have the correct media selected not metric but inch, check your driver setting also inch not mretric no A3 or A4 that metric
May 20, 2014 | Konica Minolta magicolor 2490MF Laser...
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
My machine gives me error code 18h wont do anything
Are you sure it is an 18h? There is no such error code for this manufacturer anywhere. What cycle was it in and what was it doing/not doing when this happened?
Sep 04, 2012 | Frigidaire Affinity ATF7000E Front Load...
Describe 102-372 code problem in m24 xerox work centre
Solution : Power OFF the Printer, Wait 45 Seconds, Then Power ON CAUTION: If the machine is powered OFF / powered ON, all information that is stored in the machine's memory may be erased.
NOTE: Before powering OFF, make sure that all copy or print jobs have completely finished. Never power OFF in the following instances:
  • While data is being received.
  • While jobs are being printed.
  • While jobs are being copied.
  • While a scan is being executed.
  1. Power OFF the machine. The power switch is located on the front right side of the machine under the Control Panel.
    NOTE: Before the machine is powered ON again make sure the Touch Screen is blank.
  2. Power ON the machine.
    NOTE: When the power is ON, a 'Please wait...' message will be displayed. This message indicates that the machine is warming up and cannot be used. After 45 seconds, the machine becomes ready for use.
    If the issue is not resolved repeat steps 1 and 2 a second time.
Mar 07, 2011 | Xerox WorkCentre M-24 Color Copier
Brother 130c print unable 50
Solution #1 is absolutely spot-on from adnanbhatti, copy the link into your browser to be able to see the photos of the printer and how to slide the print head:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000500/000065/faq000565_013.html?reg=us&c=us&lang=en&prod=dcp130c_all&Cat=11
When I slid the print head over as specified, I found a little crumpled paper fragment soaked with ink. Pulled it out.... I turned on the printer, it ran a cleaning cycle automatically, and started printing just fine!
Aug 18, 2009 | Brother DCP 130C All-In-One InkJet Printer
I can't print scanned material to full size.
You can try the freeware at the link below:
http://www.bestsoftware4download.com/software/t-free-freekapture-download-npbskbaz.html
The description states: "You can also use FreeKapture as an 'ad hoc' copy machine (by using your printer drivers 'how many copies to print' option)."
It works with all twain compliant scanners. Download and install and then point it to your scanner.
Good luck, and please let me know how it works out for you.
Mar 19, 2009 | BenQ Scan to Web 4300U Flatbed Scanner
Printer message: Unable to Print
5A: encoder disc or encoder strip or main circuit board or printhead circuit board or power supply defective!
Sorry, cant be fixed by yourself!
Feb 20, 2008 | Brother MFC-440CN InkJet Printer
UNABLE TO PRINT
press menu then start bk copy then fourtimes arrow-up button (tel.index) quick after another.
machine will be in maintenance mode and lights will flash.
press start bk copy in case machine wont directly display the error code.
Error starting with 4 means defective print head.
Error starting with 5 menas defective purge station or cycle problems.
both error series means: you need a new printer...
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Konica Minolta magicolor 2480 MF All-In-One Laser Printer Logo
236 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
