Question about Goodman CKL60AR60 Air Conditioner
No air flow
No air is blowing form the ducts when the unit is on
    Guru:
  • 1,524 Answers
Check the circuit breaker for the "Air Handler"
Posted on Apr 23, 2009
Weak hvac air flow blow motor works great
tear apart ducts and check for nesting issues-Denny
Dec 31, 2013 | 1998 Pontiac Bonneville
Does not blow air through ducting
sounds like duct damage or restriction in duct work.
Sep 02, 2012 | Dometic 457915 Duo Therm Brisk Air...
My amana nde5800ayw has been taking hours to go through a dry cycle. What can I get to fix this. Thanks
If the unit is getting hot then the most common problem is air flow restriction.
Make sure the unit is not pushed to far back against the wall to block or pinch off the ducting,then when the unit is running go outside and find the vent and feel how week or strong the air flow is.
If the air flow is week then you have a restriction some where in the main vent line and needs to be cleaned.
You can use a leaf blower if you have one to stick in the ducting on the inside of the house and blow everything to the outside make sure to remove the outside cover first.
Dec 02, 2010 | Amana Dryers
Just Installed a Dometic Rooftop air conditioner I Have 2 supply ducts that feed each end of the home the supply duct are not putting out any air when I took the cover off the unit seems to be blowing out...
Usually in moble homes the air flow has terrable air restiction in most cases this is compansated with higher volumes of air flow (your gong to have to increase the blower fan speed to compensate. hope this helps
Aug 19, 2010 | Dometic Rooftop RV Air Conditioner
Centeral air conditioner
If cool air is moving through the duct work,(feels cool or cold) and the area outside the duct work is warmer/hot, then you will get condensation forming on the duct work. Wrapping the duct work with insulation should lessen, or eliminate that.
Jul 10, 2010 | Heating & Cooling
The front ac unit has very poor cooling and left running, freezes up and drips water out of the ceiling grill. I s the unit shot?
Ensure the air filter and evaporator coils are clean. If they are clean and everything is running properly, then the unit may need refrigerant. It depends on the age of your equipment and the location of the leak (price to repair) as to whether or not the unit is shot. Check your air filter and evaporator coil first. :-)
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
What is the difference between ducted roof air and non ducted.
Non-ducted units blow the cooled air out louvers on the unit. Ducted units discharge into a duct system like your home furnace. (Or RV Furnace (heater)).
Apr 10, 2010 | Dometic Rooftop RV Air Conditioner
Stops blowing air
remove cover at ceiling so you can see in at fins and see if they are frosting up bad. If they are, I suspect during AC installation, they didn't open up ducts on discharge properly and air flow is restricted, which will cause freeze up, especially if low flow from discharge ducts. I'm assuming it is a ducted system. You may have to remove or drop down entire ceiling assy, to see if the ducts into ceiling have any blockage. Sometimes they don't cut rubber roof material back far enough, or misaligned ducts and cause restricted flow to ceiling vents, which will cause unit to frost up, which kicks out compressor until frost is melted, then compressor kicks back in and cooling happens again.
Apr 06, 2010 | Dometic Rooftop RV Air Conditioner
Blowing hot air
Water in the pan is normal, this is the humidity removed from your space. Pan must be emptied regularly. If the unit shuts down after 15 minutes, you may have a blocked hot air duct. Make sure it is flowing freely. This includes makeup air from outside the room to replace that blown outside by the AC.
Jun 24, 2007 | Sunpentown (EHW10268) Air Conditioner
Goodman CKL60AR60 Air Conditioner Logo
48 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
