Question about Amana ABB1921WEW - 18.5 cu. ft. Bottom-Freezer RefrigeratorWhite
Amana ABB1921WEW leaks, ice forms in bottom of freezer under basket.
aborcass
  • 2651 Answers
SOURCE: Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
Posted on Mar 12, 2008
SOURCE: Amana Bottom Freezer
amana bottom freezer has brown liquid draining on floor near the left leg
Posted on Jan 10, 2009
  • 48 Answers
SOURCE: too much water in amana bottom freezer ice maker
Try closing the valve partially on the incoming water to the icemaker. Close it to a trickle. Water is fed to the icemaker by a short timer. Too much water pressure means too much water. If this helps it but not solve it, get the spec sheet for the icemaker and adjust to make cubes smaller. This shortens the timer. If no joy, you may need to replace icemaker module.
Posted on Sep 01, 2009
SOURCE: Amana Temp Assure bottom
I am having a similiar problem. How is your seal - check the gasket and see if there is any separation from the door where air could get in. I had our gasket replaced several years ago but the door was not level and the seal pulled away from the freezer in the upper left corner allowing air to get in and make snow in the unit. Now the compressor has trouble kicking on after the auto defrost. We hear an electric buzzing sound every 20 seconds or so. Fans run but the unit doesn't cool. If we pull it out and unplug, wait and plug back in it usually starts back up. I have read that rather than replacing the whole compressor we may be able to just replace the relay,overload and run capacitor assembly - looking into that now...
Posted on Dec 01, 2010
allbrands
  • 600 Answers
SOURCE: Ice is forming on bottom of freezer under
Hello, Thank You for using FixYa. I will be helping you today.
You have a frozen drain. You need to remove the back panel in the freezer. Do not touch anything behind the panel and dont poke anything. You need to remove as much ice from the bottom as you can. Then use boiling water to pour in the bottom section under the evaparator,I would put a towel in the unit to help catch the water. Keep adding new hot boiling water until the drain clears up and the water starts to drain. It can take a while sometimes the whole tube will freeze. You can add a duckbill to the end of the drain hose behind the unit to help stop this from happening part number
8055306 Just push it on the end of the drain line.
Thank You and please rate my answer if it was helpful..
Posted on Jun 17, 2011
Testimonial: "very very helpful,was the perfect solution, thank so much"
Wood freezer f17wce bottom ice
There is water accumulation at the bottom under the basket it forms a thick piece of Ice that we have to break in order to remove it every second day what can I do ..
Feb 24, 2014 | Woods Upright Freezer MU07W
Amana freezer forms ice on the bottom. We have taken it apart, cleared ice from coils and drain, turned down freezer temp, but it still happens. Fridge works fine. Any other ideas?
When you see that ice forms on the bottom of your freezer it is most likely means that the drain hose of the fridge is blocked.
You will need to take the panel inside the freezer off, clear all the ice and pour hot water into the drain hole until you hear the water coming out at the beck where the compressor is located.
The next step would be running a 1/4" hose thru that hole.
Good luck.
www.QuickFixAppliances.ca
Oct 07, 2013 | Amana ARB8057CSR Bottom Freezer...
Amana Bottom Freezer ARB220CW Ice forms on the bottom of freezer and water drips out of door
This is most likely caused by a blocked defrost drain behind the rear panel of your freezer. Either ice or sludge has blocked the drain and now when your refrigerator goes into defrost it has no where to go but the bottom of fridge and onto floor. Click Here=> Leaking Refrigerators, Just What may be Happening once there then click HERE=> Leaking Refrigerators! Every refrigerator is different so if you have questions let me know, Thanks, Sea Breeze
Oct 13, 2011 | Refrigerators
Too much water in amana bottom freezer ice maker
Sep 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
My Maytag side by side (no icemaker) keeps leaking water under the freezer side front roller area. Ice is forming on the inside bottom of the freezer under the bottom basket. I've vacummed underneath and...
OK, You need to unplug for a hour or so. Remove the rear panel in back of freezer to expose the evaporator coils. At the bottom of the evaporator there is a tray that catches the defrost water to take it through the back and down to the condensate tray located near compressor and condenser fan. Most likely you have ice or something trapped in that drain beginning in the freezer. I have heard some people turn the freezer temperatures so cold ice will form before the water can drain. If you still have problem contact me. If this helped vote or rate me. Thanks Sea Breeze
Jun 22, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Amana ABB1921WEW - 18.5 cu. ft. Bottom-Freezer RefrigeratorWhite Logo
35 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
