Question about Do All Traps Do All Outdoors White Wing Automatic Trap
When I put the trap into disarm mode the mother keeps running, when I load the clay targets into the machine it breaks them when it throws.
White wing thrower, will not stop throwing clays as soon as you turn it on.
[PDF]TROUBLESHOOTING AUTO TRAPS - kivelaoutdoor.com
www.kivelaoutdoor.com/.../TROUBLE%20SHOOTING%20AUTO%20T...
Is the throwing arm stalled while motor/gears are turning? ... "The Trap worked well at first but after a box of targets it started breaking a lot of .... Throwing Arm when to stopin the cocked position by killing the power to the motor when ... Arm doesn't move to the Disarm position when the unit is switch to Disarm, it could be that.
Sep 14, 2015 | Mtm EZ Throw II
The arm on my clayhawk full **** clay target thrower won't throw!
Anything with this much force in it is dangerous to work on unless you are totally knowledgeable. Seek help from a shop/dealer.
Dec 14, 2013 | Do All Traps Clayhawk Full Cock Clay...
Concrete tile or Clay tile
clay tiles have little more lifespan than that of concrete. While clay tile is only popular in its red color, concrete tiles are available in wide range of colors.
Clay tiles break easily but concretes do not. But both concrete and clay tiles are the pinnacles of beauty.
Dec 09, 2013 | Washing Machines
The machine at times just keeps on shooting out the clays when not even pressing the remote peddle. It does it even without the remote plugged in.
For something like this, I think your best bet is to contact the company:
Do-All Outdoors, LLC.
1207 16th Avenue, South
Nashville, TN 37212
Customer Service:1-866-SHOT-DOC(1-866-746-8362)Email:customerservice@doalloutdoors.com
General Numbers:
phone:800.252.9247
615.269.4889fax:800.633.3172
615.269.4434
Oct 07, 2013 | Do All Traps Do-All Outdoors White...
What are the best chokes to use for a beginner on clay pigeon shooting?
To increase your odds of hitting targets - use the most "open" choke that will maintain good density at the distance you're shooting - exactly the same as most experienced shooters do... Skeet choke for shooting Skeet, Mod to Full for Trap, Cyl to Light Mod will handle 95% of shots on the sporting clays courses around here.
To increase your skill - occasionally use your full choke for everything until you learn proper gun mount, swing, and lead and follow through. When you start getting frustrated, switch back to the open chokes to get a little positive feedback on some close targets, then move back to the full choke.
Jan 17, 2013 | Sport & Outdoor - Others
Is there a lint filter I can clean in the Whirlpool Duet? I have water come up out of the drain pipe when it empties. I already put drain cleaner down the pipe but water still comes out sometimes. is there...
its your drain pipe thats blocked up,, i take it its the one that the washer is pushed into and go's out the wall to the drain that the water is coming back up from,,,in all sope powders there mostly made from a "clay base" so the out let pipe is blocked with "clay wast" push a cleaning rod down the outlet on the wall,,,down to the drain to clear it out its not likley to be the washer thats blocked up,
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frontloader door keeps breaking
Call your retailer directly to make you whole.
Video tape the events and send an email to Kenmore.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore 44102 Front Load Washer
Whirlpool front load model#ghw9100lw2 Sour smell in trao
TRY RUNNING A COUPLE OF HOT LOADS(EMPTY) WITH DISHWASHER DETERGENT THIS WILL HELP BREAK UP THE MILDEW BUILT UP IN THE MACHINE
DO NOT USE DISH SOAP!!!!!!!
Feb 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Do All Traps Do All Outdoors White Wing Automatic Trap Logo
120 people viewed this question
Top Do All Traps Sport & Outdoor - Others Experts
Bill Eager
Are you a Do All Traps Sport and Outdoor - Other Expert? Answer questions, earn points and help others
