Question about Ovens
Cda 9002/2 ss the center fan element has been
Cda 9002/2 ss the center fan element has been replaced as we thought it was the problem, but the oven still gives out no heat when on this setting, could the problem be somewhere else. ? thanks in advance
  • 833 Answers
SOURCE: SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
Posted on Dec 07, 2007
barkencoa
  • 3463 Answers
SOURCE: fan oven not heating up
If fan is working then the element has probably gone
Posted on Nov 30, 2008
barkencoa
  • 3463 Answers
SOURCE: smeg oven
Sounds like you need a new oven element fitting.
Posted on Dec 08, 2008
Macmarkus
  • 2605 Answers
SOURCE: Large oven doesn't heat up. Heating element gone??
Hi, In a word yes. As for who you can contact, I'd suggest only an authorized b/s/h (bosch/thermador/gaggenau) service provider. I used to be one for over 10yrs. but now work exclusively for sears...I'm not sure if I made a good choice or not yet, lol ! I digress. It is quite possibly not even the element as the gaggenau have cut-outs (they are actual thermal fuses that cannot be reset, they must be replaced) built into the bake circuit that can open often times. This of course unless you're certain the bake element is defective. Check your local directory under appliance service or a vendor who sells that line may be well equiped to direct you for quality service in someone they trust and are proficient. Hope that helps, good luck. macmarkus :)
Posted on Nov 10, 2009
  • 133 Answers
SOURCE: The bottom (fan oven) of my Neff U1721 made soft
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Posted on Dec 15, 2009
Cda dc940 ss oven heats up then fan cuts out and oven cools
thermostat fault or control dial /buttons faulty
Apr 05, 2017 | Ovens
When on fan symbol only and with a temperature set manually, the oven will not heat. The bottom and top heating elements will heat up seperately on other settings
My oven is DOP705X. It had the same problem on two occasions. First time it was simply the fan element. Second time I thought it was the element so replaced it again, but no fix. Turns out it was the relay for the fan element, it had got sooty and black. A quick clean of the contacts with emery paper and it was all working again. If the relay needs replacing, a new one is £2.88 from RS Components, but replacing it will require a spot of skillful soldering.
Sep 29, 2014 | De Dietrich Ovens
How to fit an element in a cda dc730ss oven
You have a wire loose or breaker tripped. Turn off breaker to oven then reset it.
Feb 24, 2013 | Ovens
How do I replace the bottom oven element in a CDA CD 907 double oven
ISOLATE MAINS POWER BEFORE WORKING ON THIS APPLIANCE
Remove the back of the oven check temp controller before replacing or buying element, as this can often stop any heat being produced. The element is in front of the fan, if this model is fan assisted, remove fan, after removing element inspect to see any small hole in metal, if you see a large hole more than 10mm , this could be a sign that the fan needs cleaning. Clean fan with WD40, do not switch oven on untill fan has dried off. Then replace element, switch oven on low with door open, if you feel slight heat, go for a full test, gradually build up heat, keep on for at least 30 mins, make sure the oven reaches temp, you can expect some smell from a new element, this is protective oil, and considered normal.
May 10, 2011 | Ovens
Am trying to remove the element in my neff u1271n2gb oven but cannot get to the screw that is holding the clip that is attached to the element it is at the top mostly hidden behind the fan no-one seems to...
To undo the nut that secures the fan, unscrew it CLOCKWISE as though you were tightening it, as it is a left hand thread, and vice-versa for tightening it back up.
Please rate my solution.
Thanks.
Nov 17, 2009 | Neff U1721 Double circotherm Electric Oven
My CDA fan oven will not get hot
Ok , classic example of a fan oven element blowing, take the cover off inside the cooker held on by 4 screws so you can see the round element, you should be able to see where its blown a big hole.
replace element
( make the cooker is turned off of course)
Sep 18, 2009 | Ovens
Replacement fan element fails to heat up.
two thoughts
is the thermostat open circuit?
there is sometimes an overheat stat adjacent to the element behind the outer casing. this can go open circuit
Dec 01, 2008 | Hotpoint Ovens
3rd blown element
no connection between lights on fan. problem is that bulbs these days are poor quality (but cheap)
it is common for these circular elements to go. usually last about 2 years. worth checking tho that fan is turning at right speed
Jun 21, 2008 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
43 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
