Question about Acer TravelMate 2355LCi Notebook
My laptop not start at all
Mine is not start all with or without ac adaptor. swith is on ( green light).
  • 35 Answers
Do the fans turn? Can you hear the hard drive turning? Looks like a motherboard problem Try without the battery and only the charger
Posted on Sep 27, 2007
SOURCE:
I have an acer aspire 5100 and here recently the
Could be a bad battery and/or charger/AC Adaptor/DC Connector. Try to isolate the problem by removing the battery and then plugging the laptop charger in and starting the pc up. It should boot on the AC adapter alone. If it won't boot on the AC adaptor or it flickers and flashes while on the AC adaptor, I would first suspect the AC adaptor or the DC connector on the laptop (try wiggling the power plug at the PC to try and check the connector). If it behaves while on the AC adaptor without the battery present, I would suspect the battery. Either way, you may have to replace something.
Sep 04, 2014 | Computers & Internet
Th ebattery light flashes contiuosley from green to orange even when the ac adaptor is plugged in the mains .do i have faulty battery as well as a faulty aadaptor ?
Joanne, remove the battery and unplug the power adapter. Now replug the power adapter and start the laptop without the battery. If all is well then you've determined the fault is the battery. Which is very common on those laptops. -Ravi Shanghavi
Aug 19, 2010 | Dell Latitude D610 Notebook
Screenblinking blinking
yes replace ac adapter. light on ac adapter does not blink
Mar 07, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Compaq armada 7400 does not turn on
Please turn off the Computer and disconnect the AC Adaptor then remove the Battery. Next, try cleaning the metal contacts on the Battery and reseating the RAM modules.Then, connect only AC Adaptor to the Computer and try to turn it ON without the Battery. If the Computer doesn't turn ON then disconnect the AC Adaptor and insert the Battery then try turning ON the Computer. If the issue persists even after performing all the above steps then service will be required.
Jun 23, 2009 | Compaq Armada 7400 Notebook
No power to dell latitude d600
have you checked your ram? remove it and see if it powers on and qickly turn off. if it powers on replace ram after shutdown. if problem not fixed coud be cpu problem or mobo.
Jun 02, 2009 | Dell Latitude D600 Notebook
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
May 31, 2009 | Dell Inspiron 1300 Notebook
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
May 04, 2009 | Dell Latitude D600 Notebook
Changara
Try turning on the system without the AC adaptor. If it doesn't work on battery, then try pressing and holding the power key (after removing the battery) for 30 seconds.
Now attach the AC adaptor and try to power on.
If it doesn't work, it sounds like either a motherboard issue or an AC adaptor issue (possibly there isn't enough voltage being supplied) but it's an odd problem. I hope I helped.
Stay spicy, and happy lappying! :)
Dec 16, 2008 | IBM ThinkPad A22e 2655 Notebook
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Toshiba Satellite 1405 - Power problem
Hi Don
Although symptom is showing that AC Adaptor is not working as its not providing power to the unit. I will suggest you to perform some basic troubleshooting steps. Check if outlet is working if not check with known working outlet. If you have a multimeter you can the output of the AC adaptor.
Also you can perform full power cycle and component discharge. Take the battery out and disconnect the AC adaptor press the power button and hold about 7 seconds. After that put the AC adaptor in and test again.
If issue persist take to nearest Service center check with known working AC adaptor. After that I believe you will figure out the best solution.
Good Luck
Jan 21, 2008 | Toshiba Satellite 1405-S151 Notebook
Acer TravelMate 2355LCi Notebook Logo
42 people viewed this question
Ekse
Alun Cox
