Question about Canon imageRUNNER 7200 Copier
Xerox 5675 atasca y da franja negra. - Canon imageRUNNER 7200 Copier
Half print from the Bypass tray:
Change the paper settings of bypass tray for required size in settings menu.
Nov 21, 2014 | Xerox WorkCentre 5687 5675 5665 165 275...
Local interface problem detected
interface is like the units have to be compatible to work
most of these messagers is an indication that a driver is missing
Feb 04, 2013 | Xerox WorkCentre 5687 5675 5665 165 275...
Tengo un acer aspire 5100 bl51 cuando la enciendo en la pantalla no aparece nada y esta toda negra no se que pudo suceder estaba descargando videos y de pronto se oscurecio la pantalla se escucho un...
Desconecta la bateria principal y Desolda una bateria chiquita que trae en la tarjeta madre (Posiblemente este debajo de la tarjeta Inalambrica).
Luego manten precionado el boton de encendido durante unos 10 segundos. Luego conecta todo y Listo. Ya que compruebes que te da Video le soldas nuevamente la bateria. Eso es Todo
Aug 30, 2012 | Computers & Internet
I have a 7750 xerox printer. paper keep wraping around the fuser roller and jamming. the fuser has been used for only a short time. Is this a damage unit and need to be replaced or is there something I...
Hello sir; Try to move out fuser unit, check the fingers against the fuser rollers, does it build up toner on the finger tip if it does, clean it up otherwise replace it.
Nov 06, 2009 | Xerox Phaser 7750DN Laser Printer
Feedroller on mdf on xerox 5675 keeps jamming. The copier has done over 200,000 copies so I'm assuming the feedroller needs changing but as yet no message has appeared to do so. Any advice?
You are right, the feedroller is worn and needs to be replaced. Is your copier in an office or your home? Is it a copier bought by you personally or by your company? The reason for that is, Xerox never sells copiers to businesses without pushing a maintenance agreement on the customer. With that, there is an 800 number in the user manual for service and sometimes the number is posted on the copier. Unless you have a tech available to order and replace parts, you will have to call Xerox.
Oct 20, 2009 | Office Equipment & Supplies
Fotos negras
ente alterar sua exposição a um ajuste diferente.
Você está sob expo
recorda isto.
Números grandes = números pequenos
da abertura pequena = abertura grande
F1 2 3 4 5 6 7 8 Ideal grande para a luz baixa (noite e noite)
9 10 11 12 13 14 15 1 6 +…. ideal pequeno para a esperança clara brilhante (da luz do dia
) você pode traduzir minha tentativa em Potugues
Aug 19, 2009 | Fuji FinePix S1000FD Digital Camera
XEROX PHASER 3500. 8220 FUSER FAILED #8221. OVER HEATING AND BURNING SMELL.
LE HE CAMBIADOS DOS VECES EL FUSOR A LA IMPRESORA XEROX 3500, SE HA DAñADO SUPUESTAMENTE POR CAUSA DE LA ELECTRICIDAD, USTEDES ME RECOMENDARIAN USAR OTRA O SABER SI EL FUSOR REALMENTE HA SIDO REPARADO Y POR ESA RAZON VUELVE A DAñARSE.-
Jun 24, 2008 | Xerox Office Equipment & Supplies
Canon imageRUNNER 7200 Copier Logo
16 people viewed this question
old marine
old marine
