Question about Vehicle Parts & Accessories
I need programing instructions for directed gm bypass module 11700G
  • 53 Answers
You can go on to directed electronics website and get the manual for the bypass
Posted on Jul 14, 2009
What fuse on a 1991 cadi elderado do i remove to disarm anti theft system
The alarm is not fused. Would you like to bypass it? It is fairly easy, takes about one hour, the only catch is that you must have a working PASSKEY module. The bypass eliminates the need for a chip key or in you case a resistor key.
Follow the link for instructions. How To Permanently Disable GM PassLock System
Jan 23, 2017 | Cars & Trucks
How can I program new key fob and where is the sensor located?
I think i know how to help u with your issue. I had the same problem. If you check out this site it has a module that will bypass it all together and you will not have any issues. The module is guaranteed and you can put it in yourself so that will save you $$. I hope this helps ya
Do It Yourself GM Security bypass
Mar 11, 2016 | 1998 Buick LeSabre
Bypass tcm module 2003 chevrolet truck
Depending on your level of handiness you can use a multimeter and resistors to permanently bypass the factory passlock. Although it isn't the best way to do, it is inexpensive and effective.
Nov 07, 2013 | Directed PLJX GM Self Learning Passlock...
Tcm module
TCM ,
how to bypass all transmission shifting?
why?
please be clear.
what is wrong now, ?and or , what is your goal if nothing is wrong.
we can not guess.
I would like to know which wires and where are to be found to connect a universal alarm and central locking module on a terios(2006)...
My name is Israel and I would be glad to help. First I need to know whether you have installation instructions to the alarm. If you do great. I would still need the make and model of the alarm and year, make, and model of your vehicle. As soon as you send me all of the information I will get you what you need. Hope to hear from you soon.
Feb 22, 2011 | DEI GM Immobilizer Bypass
What is the passcode for the anti theft system
his vehicle has a the PASSLOCK II key
based engine disabling system.
You can attempt to put the key in the ignition,
turn it on to just before cranking and then leaving
it that way for 10 mins. After that,
some PASSLOCK systems will re learn the code
and allow for starting. But if not, the system
will either need to be seen by GM or, a bypass module
is required to circumvent.
If left unchecked, it will continue to lock down
the fuel injector rail, and you will need to tow
it in to GM for evaluation, and resetting anyway.
Bothersome, but can be fixed.
I suggest the PLJX bypass kit to get around
this issue. www.PASSLOCK2.com
This Passlock Bypass Module is designed to momentarilly
allow the engine to remote start by sending a proper
coded pulse to open the fuel rail passlock injector
cut off circuit.
The output from an alarm/remote starter
would then shut down the pulse, once it has detected
the engine has engaged, and preserve the integrity
of the passlock system.
That is it's designed purpose.
However, in your case, this input wire on the PLJX module,
instead of going to a momentary ground pulse from
an alarm/remote starter,
would go to a constant chassis ground, through
the bypass module, grounding out the PASSLOCK.
The PASSLOCK would then always be bypassed as long
as that wire is chassis grounded.
I can not speak about a damaged passlock system,
like if a thief has destroyed it, because I do not
get into this part of GM'S security application.
But as a happy coincidence to installing
after market remote starters, this does work on bypassing
passlock in most all GM vehicles we've run into,
including your year GM vehicle as well.
Also, this is a self learning, resistor sensing
and adjusting module. Once the VATS wires have been tapped,
you would press the program button to learn,
and it does. The car should then allow start
with any hardware store key.
It would on yours as well.
You might want a car alarm installer to do this
for you, the fair rate being around 50. to 75.
for labor.
Jan 26, 2011 | 1999 Chevrolet Malibu
What does an audiovox FLTB2 do, how does one hook it up. Is it any good.
The FLTB2 is an immobilizer bypass module for GM vehicles. It is designed to bypass the resistor based GM anti-theft system.The FLTB2 works on numerous GM vehicles and, it must be programmed for the particular year/make/model of the vehicle. To program the unit you need a flashlogic updater. This device plugs into a computer USB on one end and the FLTB2 module on the other. You need to download the weblink driver at flash-it.com for the updater and the FLTB2 to be recognized. After you have downloaded the driver, plug the updater into your computer. Next, plug the updater into the FLTB2. Select "Update Module" at the top right hand of the screen.The current firmware will be displayed. Click next. Click on flash by vehicle. You will then be able to select the year/make/model of the vehicle that you intend to use the module on. Click "select vehicle" . You will then be directed to the page to flash the module. Click on flash module. The screen will display a status bar for the programming process and will prompt you when done. You will also be directed to the left side of the page to download the installation instructions particluar to the firmware just downloaded. Please read carefully. The instruction usually display numerous installation instructions for several different vehicles. You will have to find your particular vehicle by year/make/model, look for install type and proceed from there. Also, pay particular attention to the programming instructions. If you are hardwiring the module to the remote starter, be sure to select hardwire in the programming sequence. Enjoy.
Nov 27, 2010 | FLTB2 Data Immobilizer Override for GM...
1100F DEI bypass module on a 2003 sport trac
if nothing else just use the "key in the box" method for bypassing the explorer, only thing is you will loose a key, good luck
Nov 23, 2009 | Directed Electronics 1100f Ford Pats...
2004 pontiac Grand Am with security passlock starting problems
Unfortunately you are correct, this
vehicle has the PASSLOCK II key
based engine disabling system, and currently it
is engaged. The sensor does not recognize &
retain the passlock reader chip in your ignition
switch any longer.
A bypass is required to circumvent.
If left unchecked, it will lock down the fuel injector
rail (as it has now), and you will need to
tow it in to GM for evaluation, and resetting.
Eventuall, the 10 minute over ride will cease to
work and you will finally be forced to visit
a Pontiac/GM dealer.
But, if you want to just remove this system
from the equation entirelly,
this issue.
cut off circuit.
Coincidence to installing
passlock in most all GM vehicles,
Sep 12, 2009 | 2004 Pontiac Grand Am
How to install a DEI/BOA 555L GM Passlock 1 & 2 Immobilizer Bypass
goto www.bypasskit.com and click search by product, follow the instructions to download the instal manual, good luck
Sep 06, 2009 | DEI GM Immobilizer Bypass
Vehicle Parts & Accessories Logo
75 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
