Question about Carrier 52CQ-312-4 Comfort Series Heat Pump Air Conditioner
Carrier furnace high Efe
My furnature dose not turn on at all evene if tempratur is getting blow. i did chick power it is ok when you turn off and than on the furnce power is working for abut 45 second than again not thing going on as heat or any thing ales at all.
    Guru:
  • 1,524 Answers
Check the control board.
Posted on Apr 23, 2009
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
What is the tonnage of a carrier furnace model number 58gp100-2
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
Apr 07, 2015 | Heating & Cooling
Carrier 58STA/STX furnace false starts even when off or temperature set lower than current.
Is it possible the drain is plugged? The newer furnaces have a moisture drain and will shut down if they are blocked., shutting them down and restarting will reset fault, but will come right back if not fixed.
Dec 24, 2014 | Carrier Heating & Cooling
I have an older Carrier furnace type 58ss. The main burner will not ignite. Operating look ~ thermostat set @ 78 deg, switch furnace on, inducer fan running, pilot light clicks and ignites, inducer still...
power to gas valve ok .. Replace gas valve after checking gas valve coil for continuity/resistance... with valve removed ...and power to valve ... try blowing thru valve from supply side ... stuck valve.... replace...
Nov 01, 2013 | Heating & Cooling
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace burner turns off and on
The furnace is likely over heating and the high temp. safety is shutting it down. It then cools and starts again. Things to check: Filter, Blower wheel and indoor A/C coil. If any or all are dirty you are limiting air flow and need to clean them.
Jan 17, 2009 | Carrier 38CKC042 Air Conditioner
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Carrier Furnace wouldn't light, fan was running all the time.
Most furnaces have a photo cell if it gets dirty the photo cell does not see a flame so it trips the reset button on flame failure.
May 13, 2008 | Heating & Cooling
Carrier Gas Furnace
There is no pilot light, its electronic start now.
like your stove should be.
you can trigger the furnace by shorting out the correct combo on the thermostat but not advised unless you know the right ones.
be sure the power is on the the transformer that provides power to the thermostat.
though that may be contained within the furnace now days.
just check your fuse box and call a tech.
Jan 26, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
69 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
