Question about John Deere Garden
Model 316. Why does it stall and backfire when i try to advance the throttle to full power?
  • clem witt
    clem witt Nov 11, 2015
    i had a mower that had fouled plugs that did the same thing, replaced the plugs and ran right
  • John Deere Master
  • 2,760 Answers
It might be that your throttle cable has stretched a bit and your really in choke position when its lined up for "run" on panel marking
Posted on Nov 18, 2015
5 Suggested Answers
jimmy nutron
  • 132 Answers
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Posted on Jun 04, 2009
nova2nv
  • 197 Answers
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Posted on Nov 14, 2009
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
nova2nv
  • 197 Answers
SOURCE: john deere 318 wiring diagram I replaced an bg 316
Purple wire goes to the solenoid on starter.If you installed starter with single wire post all you have to do is mount a solenoid to the frame just in front of starter,existing batt/starter cable goes to one solenoid post,purchase a short red cable and install on other solenoid post and run it to the starter,plug purple wire into new solenoid and the way you go.
Posted on Nov 16, 2009
Testimonial: "This was great advise bought a solenoid and away i go thx"
  • 6468 Answers
SOURCE: my 316 john deere alternator is not charging the bat. Where can I get a electrical dia. to trouble shoot. Bob
there are three wires at the regulator two from the alternator and one that goes to the battery see if there is voltage at the two from the alternator if so the regulator is bad
Posted on Sep 22, 2012
VORTec 5.7L. backfires at startup and now it goes to full throttle...why
These vortec engines are prone to leak fuel from fuel pressure regulators inside the intake manifold ,an from injector pop it valves . How to replace the spider injector on Cheyv motor 4 3 or 5 7 liter check out this guys video
Dec 02, 2015 | 1997 Chevrolet Suburban
What causes my 1965 4 speed mustang to backfire and sometimes stall?
backfiring is ignition of the fuel mixture while an inlet valve is still open. Check firing order as there may be a HT lead crossed . If it backfires then the mixture is burnt in the inlet manifold so there is nothing left for the cylinders so it will stall. If you are running holley carby then check the power valve for a hole in the diaphram Check for vacuum leaks. check ignition timing is correct and not too far advanced. if the HT leads are touching each other this will induce a spark in the wrong cylinder --use lead spacers from an auto spares shop
Dec 25, 2014 | 1965 Ford Mustang
I have a 1999 Jeep Grand Cherokee. It was running good but then all of a sudden it starts running rough. You can be driving down the road and all of a sudden it will die . It will run good for about 10-15...
It could be a dirty idle air control valve located on the throttle body but when you said it backfires after running a while and before stalling, this sounds like a clogged catalytic converter. When blocked they will cause the exhaust manifold to glow red igniting gasses on the exhaust stroke, backfiring. A clogged cat will result in a loss of power as if you are trying to pull a trailer full of rocks uphill.
Oct 30, 2013 | Jeep Grand Cherokee Cars & Trucks
I HAVE A 1999 POLARIS 335 SPORTSMAN STARTS FINE WHEN I TRY TO ACCELERATE THE QUAD BOGS FEELS LIKE ITS GOING TO STALL BUT THEN GOES BUT NOT AT FULL POWER AFTER RELEASING GAS THERE IS A LOUD BACKFIRE ...
carbon on the plugs indicates flooding
the backfire indicates fuel being ignited in the exhaust
have the carby /fuel system professionally overhauled
May 27, 2017 | Polaris ATV
My engine wont rev on kickdown 1989 corvette
your torque convrtoer is shot. it is the at the front of the tranny to transfer motion from fly wheel ( engine side) to the trans. its a fairly cheap and easy fix.
Apr 06, 2009 | 1989 Chevrolet Corvette
2000 sebring won't start
Crank Sensor is the likely issue. It does not throw a code. Key indicator is the call stalls all the time. R&R sensor.
Apr 01, 2009 | 2001 Chrysler Sebring
Garden Logo
110 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
