Question about CD Technology DVD-R (44105)(100PK) 4x Storage Media
I have Sony CD-RW and Sony DVD-RW - Nero will not copy files
I have (1) Sony CD-RW and (1) Sony DVD-RW - I have DVD+R 16x - Trying to move files using Nero to move files from my hard drive to the DVD+R will not work - states insert disk when there is an empty one already in. Why won't Nero copy files?
  • 56 Answers
Your DVD-RW needs to get repair from the authorised personnal.
Posted on Apr 24, 2009
What did I do wrong? I copied doc files to a CD.
Is it a dvd-rom, dvd-rw, cd-rom, cd-rw?
What is the cd/dvd disk drive you are using?
(A dvd-rom, dvd-rw, cd-rom, cd-rw?)
This may be the problem.
Aug 22, 2009 | Compaq Computers & Internet
In CD Easy Write Reader
if this problem apperared then how much time spent you by use your cd/dvd rw i give you one suggest if you have cd writer+dvd rom then buy a dvd writer it can works or if you have already a dvd writer then check your region settings for check region settings go to my computer properties and after open properties. Go to Hardware then go to device manager and then go to properties of your drive then select the nation where you live then try it can work i think
Nov 01, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
I have an internal HP DVD Writer 740b that writes on CD but not on DVD. I tried Sony DVD RW and Memorex DVD-RW to copy files on but I failed. I use Nero Essentials to burn. The dialogue box keeps saying no...
DVD-RW drives have 2 different designs, 1 used dual optics, 1 for CD one for DVD, the other uses optics that can refocus between the media types.
If you haven't done so already, flash the firmware of the drive to the latest available from HP.
Assuming that the drive worked with NERO previously, If that doesn't resolve, you will likely need to replace the drive.
If you have not used Nero with that drive for DVD media, you might try a different SW and see if Roxio/Sonic will see DVD media in the drive.
Aug 13, 2008 | HP Computers & Internet
Please insert a disk into drive
You can only copy files to a blank disk by using programs like NERO or by using a re-writeable disk like DVD-RW which you can format and use it like a hard drive. You need also burner not an ordinary DVD or CD player.
Aug 07, 2008 | Computers & Internet
Cannot copy files to DVD disks
First of all you should have the recording tab ON. Have you tried burning using Nero instead of dragging and dropping? This may solve the problem.
However, if you prefer to drag and drop, try setting the write speed to a slower setting, even if the dvd burner has faster write capabilities.
1. I do not think it is a hardware issue.
2. You can try replacing the IDE cable, but if you can read the contents of the disk it does not suggest a communication issue between the drive and mobo.
3. I do not think that the burning software is to blame, when you drag and drop you are actually using a windows based burning software that is installed with the operating system.
4. set up your files to burn through nero, let the software do the work.
I had the same issue with my dvd burner, although slightly different error messages, solved it by using nero instead.
Apr 12, 2008 | E-Machines eMachines Desktop PC
DVD RW problem
Please use nero version nero 7.0 or you can get new version nero 8.0 from www.soft82.com/download/Windows/Nero
It will solve your problem its beter if you get cracked version of nero 7.0 from bit torent or bearshare
Regards
Balisonu79
Feb 14, 2008 | Computers & Internet
Sony DVD RW AW-Q170A Burning Problem Plzzz.....Help me out: i have two drives, 1) Sony DVD RW AW-Q170A 1.70 Ver 2) Sony DVD/CD-RW Combo RYK4 Ver My "Sony DVD RW...
Check that the writable DVDs you are using are compatible (+/-) with your Sony DVD-RAM.
Go to Windows Explorer and check to see if the Sony drive is visible. It may not be connected or the Jumper switch may be set incorrectly.
Check you have drivers installed, take a look in Hardware manager.
Sometimes, it's a little difficult to copy CDs and DVDs when you have more than one burning suite installed - for some reason, they 'just don't get along'. Try uninstalling any suites other than Nero.
Or it may just be that your Sony CD-RW drive is just that, and your DVD-RW drive is just that. So it wouldn't be possible to write DVDs on the CD-RW and CDs on the DVD-RW? Though I would assume Nero would detect that and use your hard-drive as temporary storage.
In Nero SmartStart, have you selected the CD or DVD tab to correspond to the project you're burning?
Jan 07, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
when i try to copy and paste file to DVD, through windows, a message appear says"windows encountered a problem when trying to copy this file." i dont know why, could someone help?
i'm upset now. :(
Dec 21, 2007 | Gateway GT4022 PC Desktop
Sony DW-G120A DVD RW Dual Layer Burner
U can use nero, first of all you must format de DVD-RW, so that it can be be rewritable. Then use it like a normar DVD-R disk. And every time you want to rewrite the DVD only make a quickformat and put your things on the DVD.
Nov 09, 2007 | Sony DW-G120A DVD RW Dual Layer Burner
Copying data on to a DVD
What type of application are you using? I know that the new nero requires you to choose whether you want to write to dvd or cd before it will work. maybe your application is similar.
Aug 01, 2006 | HP CD-Writer 9900ci CD-RW/DVD-ROM Burner
CD Technology DVD-R (44105)(100PK) 4x Storage Media Logo
73 people viewed this question
Top CD Technology Electronics - Others Experts
Are you a CD Technology Electronics - Other Expert? Answer questions, earn points and help others
