Question about Singer 7442 Mechanical Sewing Machine
I have a Singer 9410 sewing mach. w/ tension & peddle problems
Singer Model 9410 cannot find the tension for my fabrics. No even stitch drawn through. Too much on top or too much on bottom. Nothing available. (now using quilt cottons, 2 layers and up to 5 -- all pretty thin). Could the bobbin have something to do with this? Maybe not being wound in its nest correctly?
Also have problems with the pedal. I think the wire got pinched and now it either does a real snail slow stitch or none at all or a quick stitch that slows quickly (the later being if I took my foot off the peddle for a while).
Be sure you are using a Class 66 bobbin for this Singer machine. Using another style bobbin can cause tension problems and thread looping/bunching.
Posted on May 24, 2009
Make sure that the stich did not fall through the top thing. When you re-thread it, do it twice so you know that it is working. If it STILL doesn't work, find the recipt and return that ******!
Posted on Jan 02, 2011
I have a Singer Stylist Model #7258.Serial #H10229C25810334. When I'm sewing,the top stitch is perfect but the bottom stitch comes out like backward C's. How does that even happen!????
Check your stitch sample. Is it actually the top thread showing under the fabric, or is it really the bobbin thread. Generally, thread problems under the fabric are an upper thread problem. Thread issues above the fabric is a bobbin issue.
Try a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread.
Remove the bobbin, check that it is wound smoothly, and install and thread the bobbin case making sure the bobbin spins the correct direction.
From that point, there may need to be some tension adjustments required.
Understanding Thread Tension Threads
If the problem continues, you may need to have it serviced. Perhaps there is a burr or snag somewhere that is interfering with the thread in the thread path.
Oct 21, 2017 | Singer Sewing Machines
Singer model 2638 puckers fabric when sewing straight stitch. Have to manually keep fabric taut behind needle to get anything accomplished. Why does this occur and how can it be fixed?
If the fabric is puckering when stitching, usually it is because the tension is too tight. You may need to loosen both the top and bobbin tensions.
Another time the problem occurs is when sewing fine fabric (like chiffon). The fabric does not have enough body to lay flat, so it puckers. You can utilize a stabilizer to help give the fabric body (washaway or tearaway stabilizer, or even use light-weight paper such as adding machine tape or even toilet tissue). Sometimes some spray starch is enough to help it lay flat.
How to Prevent Puckering Sewing Machine
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwih76G2yuHNAhVBVWMKHV-1DiEQFgggMAE&url=http%3A%2F%2Fwww.amefird.com%2Fwp-content%2Fuploads%2F2010%2F01%2FMinimizing-Seam-Puckering-2-5-10.pdf&usg=AFQjCNF6q0Pk13ZU4Hb3o3RiAGBbL04l-A&cad=rja
http://www.beaconfabric.com/vindex.html?SelectingtheRightStabilizer.htm
http://www.coatsindustrial.com/en/information-hub/apparel-expertise/seam-puckering
Jul 06, 2016 | Singer Sewing Machines
Loose bottom stitches on Singer 1507
top tension must be adjusted to fix loose stitches of bottom stitches
adust the top tension one letter or number higher and sew on a scrap
piece of fabric till stitches look correct,, here is a free manual
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
Jan 06, 2013 | Singer 1507
TENSION ADJUSTMENT ON SINGER 9836C
try adjusting the top thread tension to one number higher at a time until the stitches start looking right
also check with singer customer service for a instruction manual
Feb 23, 2012 | Singer 5050 Mechanical Sewing Machine
Someone gave me a portable Singer sewing machine that is practically new. However, when I sew a fabric, the top part is stitched well but when I turn the fabric over, I see that in the stitching underneath...
It definitetly sounds like a tension adjustment, make sure the top tension is about 4 or 5 and you should only be able to pull the bobbin thread through with slight resistence, if it is too tight slacken the scew on the bobbin case about a quarter of a turn at a time and test, keep adjusting until you get it right.
Jun 18, 2010 | Singer 14SH654
Stitching tension
hi,
different fabrics and layers has diferent set up on threading. try cotton fabrics w/ thread tension of #3 to #4 and stich # 8 to #12.if you change fabric and layers gradual setting on dial tension should be done until you acquired the good set up.have a nice day.regards
May 29, 2009 | Singer 8280 Mechanical Sewing Machine
Stitches are on the reverse of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
thank's
Apr 09, 2009 | Singer 7444 Mechanical Sewing Machine
When making a straight stitch or Zigzag stitch, makes loops underneath the fabric This is for a Singer sewing machine model 5817c
Your top tensioner is too loose.make sure the thread runs through all the relevant eyes and then tighten the top tension little by little as you do a sample few stitches.
Feb 21, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 301A stitch jam
It sounds like your feed pressure and tension are both off. Try sewing with out thread. If the fabric goes all over the place, you need to adjust the feed pressure (the screw on the top of the machine). Tighten it down until your fabric feeds evenly. If the fabric is bogging and not feeding, you need to loosen it.
Your tension sounds like it is off as well. Make sure it is set around 2-3 and check your tension disc, make sure there is no thread in between the disc. If so, remove it. Now, thread the machine and check the thread through the needle. It should pull out quickly and smoothly. Now, put the presser foot in the down position and pull the thread, it should have some resistance. If not, your tension is set too low. Turn it up a little and try sewing. If the thread is still knotting up, you can turn the tension up to about 5, if that does not correct the problem, you will need to adjust the tension dial itself. To do this, press on the numbered part of the dial and it will push in, then turn it to a lower number, release and make sure it has locked back into place. Then adjust again as I previously instructed.
Feb 06, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Singer 7442 Mechanical Sewing Machine Logo
535 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
