Question about Air Tools & Compressors
I have a Rockworth 6 gallon upright 1.5 hp classic air compressor. It has 2 gauges on top. The left side compresses but the outlet side on the right gauge never increases and will not put out air. The psi adjustment dial and seal seem to be malfunctioning. How can I get a replacement ?
2 Suggested Answers
  • 1388 Answers
SOURCE: my craftsman air compressor #919176820 2 HP 12 gallon 200 max psi will not compress over 125 psi
If your compressor is oil-less type, most likely pressure is leaking past piston ring. To verify, remove cover to expose bottom of cylinder (unplug compressor and let out all air). With flashlight, examine the upper-most part of the cylinder (turn motor by hand till piston is at top of stroke). If top of cylinder is scratched, then pressure is leaking past.
For many years now, stores are in a race to have more HP and PSI to attract customers. Customer is really the loser because components used to make the units can not handle the higher pressure. Normally small 115v compressors are set to cut out at 125psi and larger two stage units will cut out at 160psi. Small compressor set to 200psi makes for short lived compressor. Could be compared to driving your car at 100mph all day every day. Longest life is attained when unit is being used at about 60 to 75 % of capacity.
To allow your compressor to reach cutout pressure and keep working for a while, lower cutout to 120psi (pressure switch may be adjustable). To restore to 200psi, replace cylinder/ ring.
If your compressor is oil type, suspect leaking reed valves.
Posted on Nov 28, 2011
Why doesn't my rockworth compressor fill up when it's running it's brand new
This could be an assembly error at the company. There are three valves in a compressor, one is an intake, one is an exhaust, one is an unloader. The easiest way to check is to put your hand on the intake air filter to check for suction. If there is suction then the valve is ok on the intake, if it flutters then it is bad or missing. Locate the on off switch and there should be a valve that unloads the pressure from the compressor, see if that is leaking.
May 05, 2016 | Rockworth Factory-Reconditioned...
Rockworth air compressor
I would think that if you are mechanically inclined at all you should be able to do that. You are right must tanks are either generic in configuration or made be the same manufacturer. I would like at worse case you may have to drill a couple of new holes for mounting your compressor.
Apr 21, 2012 | Air Tools & Compressors
How to wire a t30 1 phase 230 volt in control box, they used white black green, are the white and black both line voltage for 230 volts? its a model 2475
yes white and black are both line voltage in.each wire will have 110 to 120 volts. Attach one wire to top of starter contactor left side the other to top of starter contactor right side. Attach green wire to ground.
Jun 01, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Outlet pressure guage will not tighten, so unable to get any out going pressure? Appears to be stripped. How do I fix?
If its the female port you can purchase a 'keen sert' or other brand of thread replacemant and drill out the worn threads, tap and insert the new threads. If its the gauge, depending on the degree of damage,you may be able to run over the threads with a die or replace the gauge itself. Good luck!
Mar 05, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
Connecting the compressor to a tank
You left that question rather vague. Are you asking what material? or What size? I normally would run one size larger pipe size than the outlet on the tank, unless the distance is great. You would connect to the tank outlet which is usually 1/2 way up the side of the tank. Use only black iron or copper pipe, plastic pipe is not strong enough for compressed air. There is some plasic tubing rated for air, but that looks sloppy and isn't inexpensive eitehr. Also put a "FRL" between the compressor and piping (FRL=filter regulator lubricator).
Jul 07, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Oil dipstick and red twist knob on top of the two pressure gauges
the big red knob adjusts working pressure to hose- refer to book or dowload online
Dec 08, 2008 | Clarke Power Products AC2002A 2 Hp Air...
Air Tools & Compressors Logo
81 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
