Question about Troy-Bilt Pony Garden Tiller
Troy bilt pony left side tine assembly fell off
Troy built pony left side tine assembly fell off shaft....after replacing broken bolt
left side tine assembly wobbles...help
  • 45 Answers
Sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
Posted on Apr 29, 2009
Tines wont engage on my troy built pony. How can i fix it?
The lever for the tines moves easily? Is there an adjustment on the linkage that may need tightening?
May 11, 2012 | Troy-Bilt Pony Garden Tiller
Troy bilt pony 5hp rear tine tiller is leaking behind muffler on side of motor
Head bolts are probably loose, check the 3 nearest the mouffler and of course check all of them.
May 09, 2011 | Troy-Bilt Pony Garden Tiller
Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I cannot get my oil seals of my rear tine tiller It is a Troy Bilt 5.5 hp and I got the left side off but the right side tine attachment will not budge any suggestions please
Have you tried soaking the shaft area with either PB Blaster or Deep Creep penetrating oil. Try this for a few days before trying to tackle getting the tine attachment off.
Jan 26, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
How does the gear box come apart on a six horse troy built tiller?
  1. Remove belt guard on left side
  2. Remove belt, large pulley on gearbox.
  3. Remove throttle cable, idler pulley cable and shift handle.
  4. Remove engine, handle, wheels, tines cover and tines.
  5. Lay gearbox on side on two sawhorses, left side facing up
  6. Remove all the nuts on that side. If the three shafts have corrosion, use sandpaper to remove.
  7. Pry the two halves apart, then hammer the ends of the three shafts to push through their bushings. Use brass or wood to avoid blossoming the shaft ends. When shafts are through their bushings, the right side will fall away.
Jan 15, 2010 | Troy-Bilt Pony Garden Tiller
I need to replace the seals on my Troy-Built Pony tiller. 6 hp, ser.# 121811201149. I can not seem to remove the tine shafts. I have pulled the bolt thru the shaft but cannot budge it. Does anyone know...
I presume you opened the port and removed the grade 8 placement bolt? If you have then you need to polish the shafts with 400 then 800 sandpaper, clean then lube them before trying to slide thru the support bearings. If your tine shaft is bent? your screwed, or just remove the shaft seals with a screwdriver and replacing them without removing the shaft. REmember to put a thin coat od RTV arround the outer lip to help make a better seal
Nov 15, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
May 24, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt horse pto clutch will not disengage
The problem is lack of lubrication in the pto coupling. Losen the two swing bolts carefuly,block the front under the motor. Separate the tine transmision from the housing and grease both sides with as much grease as you can work in. Work the lever as you do this. Should fix the problem.
Jan 17, 2009 | Troy-Bilt Pony Garden Tiller
Wheel shaft seals on troy bilt pony 7 hp.
If the seal fits over the axle shaft it should be ok. be sure your axles are very clean as not to ruin the new seals when applying them. probably a good idea to replace them as a pair (right and left side) to save you time down the road.
Oct 20, 2008 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy-Bilt Pony Garden Tiller Logo
359 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
