Question about Campbell Hausfeld 26 - Gallon Air Compressor
Compressor is getting so hot it is smoking
Campbell Hausfeld Compressor is getting so hot it is smoking. I have replaced the check valve and all connections from the compressor to tank and installed new regulator - but it is still running scorching hot.
  • bmartin873 Apr 24, 2009
    I am running compressor oil. Just changed the oil to see if that would solve the problem, but it made no difference.
    Problem Solver:
  • 15 Answers
Make sure you are running compressor oil in it. Not motor oil.
Posted on Apr 24, 2009
Hot WL611200 air compressor
Campbell Hausfeld WL611200 Oilless Air Compressor This is an oil less compressor. Yes compressors do get quit hot. That's normal. Just keep the fins clear.
This
May 21, 2014 | Campbell Hausfeld FP2028 1 Gallon Air...
My 5 hp campbell hausfeld model hl 7017 pumps up to pressure but when it drops the motor starts but the compressor wont turn the belt just slips until pressure drops off to about 30 psi
Your tank check valve is not closing properly. It's a valve on the tank where the air line from the pump head attaches, It allows air in but not back out of the tank through the pump. When the pressure swtich turns the motor off, valve on the pressure switch lets the air out of the head so the motor can restart without any pressure in the pump head when the pressure in the tank drops. On rare occasion, you can clean the check valve out and it'll work again, more often than not you have to replace it.
Nov 24, 2012 | Campbell Hausfeld Maxus 60 Gallon (Belt...
I need a part number for a check valve on a Campbell Hausfeld model WL506201AJ
there is a check valve on the compressor! it connects to the tank. if it is hissing all the time it wont allow the compressor to turn over due to the back pressure from the tank... Can anyone answer what check valve to get? Tank thread size on one side and the feed tube connection side... Here is the parts diagram but the check valve is not described... http://www.chpower.com/IMAGES/pdfs/manual02/224902_0201.pdf
Feb 19, 2011 | Campbell Hausfeld Air Compressor Check...
My campbell 2 gal quiet air compressor stop working. The motor runs but no air is going into the tank, why ?
valve or internal compressor motor failure crack open fitting between compressor out put and regulator if no pressure than failure in compressor if pressure regulator needs repair or replacement
Mar 01, 2010 | Campbell Hausfeld Air Tools & Compressors
Campbell hausfeld mod wl611700aj runs for 3-5sec
If the motor isn`t bad,then the one way (check valve )is not working,putting to much pressure on the head.
Oct 05, 2009 | Campbell Hausfeld 28 - Gallon Air...
Compressor runs hot and won't build pressure
THE COPPER LINE IS SUPPOSED TO GET HOT, SCALDING HOT ACTUALLY. THE MOST COMMON REASON FOR COMPRESSORS NOT BUILDING PRESSURE IS CLOGGED AIR FILTER OR THE VALVES IN THE HEAD ARE BROKEN OR NOT OPENING AND CLOSING CORRECTLY. YOU MAY POSSIBLY HAVE A BAD AIR LEAK DOWNSTREAM BUT YOU CAN CLOSE THE DISCHARGE VALVE ON THE TANK TO ELIMINATE THAT PROBLEM. HOPE THIS HELPS OR GET YOU STARTED.
Mar 27, 2009 | Campbell Hausfeld Air Tools & Compressors
Hose from compressor to air tank
Campbell hausfeld parts are available at www.chpower.com, however, you can use standard parts like copper tube or rubber pressure hose available at Lowes lumber or True Value Hardware. Check for cause of failure of the airline, could be from vibration due to loose motor mount or faulty check valve at tank causing back pressure. Enjoy
Dec 09, 2008 | Campbell Hausfeld 13 - Gallon Air...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
630 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
