Question about NComputing X300 3 User Expansion Kit Graphic Card
Ncx-2000-xp Internal Error : 0x2025 - 0x08X - NComputing X300 3 User Expansion Kit Graphic Card
3 Suggested Answers
  • 86 Answers
SOURCE: Recently i have a problem
Where is the 'internal error' showing up, in the NComputing console, or on the Station screens? My recommendation is to uninstall the vSpace software, reboot, run thier cleanup utility, and reinstall the latest version. Before reinstalling, make SURE that you have applied XP SP3 and ALL of the current MS updates. Additionally, browse Device Manager and make sure there are NO missing or conflicting drivers. Lastly, if Intel Active Management Technology is installed, disable it. This will be listed in the ports section of Device Manager as either IAMT or SOL/COM3. Do NOT, I repeat, do NOT install from the provided CD. As of this posting date, the cleanup utility is available here: nc-eng.com/tools/ncuninstall. The most up to date vSapce for X300 on XP is at: ncomputing.com/download/x300.zip. If you hit this post later and the supplied URLs are not valid call NComputing TS at 888-365-1210.
Posted on Aug 15, 2011
SOURCE: stations stopped it says internal
Please add serial numbers and codes located on terminals in order to solve the problem.
Posted on Feb 08, 2012
I install ncx xtenda 2000 xp but shows message - internal error! What will be the proble?
Internal error means that there are conflicting applets running in the program. These can be caused by corruption or bad settings.
Uninstall every guest OS and reset everything to default. If you have just installed it then you either chose a bad option during install or the installer is corrupted - redownload it.
Nov 21, 2014 | Computers & Internet
How to convert ps2 cunnector to USB connector in ncx 2000-xp
You can buy devices to convert USB to PS/2 like this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812150091
You might just be better off upgrading to a newer PC if you're able to do so. Good luck!
Dec 31, 2013 | NComputing X300 3 User Expansion Kit...
Stations stopped it says internal error .NCX-2000-xp
1. display message as updating service
2. while updating service error display already registered yr serial number
Jul 14, 2011 | NComputing X300 3 User Expansion Kit...
Recently i have a problem with NCX 2000-xp consol i have 4 desktop one one system one the main pc is working but other three screen show internal error what can i do to solve this problem
Jun 30, 2011 | NComputing X300 3 User Expansion Kit...
NComputing vSpace not installed my pc Error
Options:
(A)
An authorization error usually occurs when more than one system in a LAN has the same software serial numbers assigned to the system. In this case, the first PC to be turned on does not suffer an authorization error, but any subsequent PC's which contain the same serial number will experience the issue.
To remove these duplicate serial numbers, first unregister them, then delete them from the host PC they are installed on:
  1. Access the NConsole application by either:
    • Click "Start" > "All Programs" > "NCX-2000-XP" > click on the entry labeled "NCX - 2000 - XP"
    • Double-click the NComputing console application icon in the system tray
  2. In the left-hand pane, navigate to "Local Settings" > "Information and Settings" > "Serial Numbers"
  3. To unregister a serial number, right-click on the number and select "Unregister now"
  4. To remove serials, right-click on the number and select "Delete"
Also, an update that does not install correctly may rarely cause corruption of the data file in which serial number information is contained, causing this error. If there are no other X-series hosts on the network with duplicate serials, then a complete uninstall and reinstall of the X-series software may fix this issue. When uninstalling, choose to unregister all serials and remove all serial registration data.
To download the latest version of our software, please search the knowledge base using "software download" as the search text, for links to the latest software.
(B)
When more than one X300 station is used under the same login (same Username on two or more stations), Active Desktop error messages may occur. Also stations would be sharing same user settings and other files, which could cause unpredictable errors.
Different stations should always be used with different usernames logged in. To add more User accounts (usernames), go to Windows Control Panel, select Users and then go to Create New User option.
Mar 10, 2011 | NComputing X300 3 User Expansion Kit...
GOOD MORNING Sir system please run the ncx 2000-xp update now or uninstall in the contral panel/software the latest window hotfix/ service patch
The update prompt is nothing more than a notification flag, it doesn't really know if there is an update available or not. Having said that, I'd recommend you do the following which should get you all set. Ap Uninstall any current version of vSpace. Reboot. Makesure you have no missing or conflicting device drivers inside of devicemanager. Also, while in Device Manager, navigate to the Ports Section andsee if there is anything listed for Intel Active Management Technology. It will be listed as IAMT or SOL/COM3. If so, right click it and disableit. Then run the NComputing cleanup utility located here:www.nc-eng.com/tools/ncuninstall.exe. Download current version for XP(v4.03.104.1) from here: www.ncomputing.com/download/x300. Unpack the.ZIP file and install. Reboot and register.Do NOT, I repeat, do NOTinstall from the provided CD and upgrade. Simply install straightfrom the download file I provided in the link. Lastly make SURE you REGISTER the CARD and the XD1 boxes.
Dec 18, 2010 | NComputing X300 3 User Expansion Kit...
How to remote desktop xtenda ncx-2000-xp
A handy little app is Logmein, the free edition is available here
Nov 03, 2010 | NComputing X300 3 User Expansion Kit...
Philips SpeechMike Executive V3.2 wont run in Vista
I had trouble initially with the same error message as deedee 222 8 and cannot give exact instructions. Try intalling old version, uninstall and then install upgrade 390 from Philips web site. I had to restart 3 times to get rid of an error messge on boot up but then it worked!
Jun 01, 2008 | Computers & Internet
NComputing X300 3 User Expansion Kit Graphic Card Logo
125 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Dan Shibata
Dan Shibata
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
