Question about camperpartsworld.com Rv Awning Vinyl Canopy Replacement, 17 ft, Camel Fade
Need info to change cambelt on hyundai atos prime 1100
How to remove a manual gear box frm hyundai atos prime
You need a manual if it's your first one. I have done several hundred transmissions. I just look at them and take them apart. Every once in awhile, I need to look at a manual.
Mar 18, 2016 | Hyundai Cars & Trucks
Where is the Computer box in the Atos Hyundai?, we want to fix it
does the Hyundai atos Prime 1.1 2008 model have a computer box
Sep 12, 2014 | 2007 Hyundai Atos Prime
Where can i get the suspension assembly diagrams for a hyundai atos gls 2008
A haynes manual will show you everything you need to know step by step with diagrams on every aspect of your car and every repair you may need to carry out.
Jul 30, 2014 | 2008 Hyundai Atos 1.1
Atos gls prime has no power when pulling off and driving
no power
1: lost electrical power
2: lost engine power
3: transmission slips. (RPM way to high)
Jul 18, 2014 | 2007 Hyundai Atos Prime
Replace cam position sensor
The Atos has a timing sensor located at the bottom of the engine by the cambelt drive sprocket (gear). The drive sprocket is bolted to the crankshaft with a timing plate. The sensor is placed next to the timing belt.There are no cam timing sensors on the cylinder head. This is a very basic engine.
Jun 10, 2014 | 2006 Hyundai Atos 1.1
Hyundai atos 2005 driving so slowly
have you had the OBD codes read at a garage this may help to point you in the right direction,sounds like a sensor(s)
Apr 04, 2014 | 2006 Hyundai Atos 1.1
Hyundai atos sensor testing
Different sensors are tested differently. Search for haynes book on Fuel Injection diagnostics. It shows how to test each sensor. You can also search for online guides to test each particular sensor.
Feb 22, 2014 | Hyundai Atos Cars & Trucks
How to adjust your clutch cable on hyundai atos prime
Wow, I cannot believe the rubbish answers posted here.
It has a simple cable setup. The slack adjuster is on the end of the cable on the gearbox side. Just where the cable passes through the mounting on the gearbox on its way to the lever.
Just turn it to take up the slack.
Dec 17, 2013 | 2007 Hyundai Atos Prime
Gearbox oil drain plug
Know where the drain plug is but cant find the place to put the oil in at the gearbox Atos gls
Apr 15, 2013 | 2007 Hyundai Atos Prime
camperpartsworld.com Rv Awning Vinyl Canopy Replacement, 17 ft, Camel Fade Logo
Top camperpartsworld.com Garden Experts
Dennis Key
Dennis Key
john h
Are you a camperpartsworld.com Garden Expert? Answer questions, earn points and help others
