Question about IBM ThinkPad T30 2366 Notebook
IBM T30 Screen Problems
With out any waring I turned on my T30 Laptop and the bottom 1/3 of the screen is just lines and mixed up colors. The rest of the screen is working fine with no problems. Any suggestions on whatis wrong and how to fix or do I need to buy a new screen?
  • djnate585 Sep 20, 2008
    With out any waring I turned on my T30 Laptop and the bottom 1/3 of the screen is went blank (verticle) but horizontal extended past view. The rest of the screen is working fine with no problems. Any suggestions on what is wrong and how to fix or do I need to buy a new screen?
More likely than a cracked screen was a bad connector. Having a band (vertical or horizontal) of random lines and colrs is typical of a bad connector. Odd as it may sound, you can try to diagnose whether this is really the case by squeezing carefully (not too hard) around the edges of the screen. On many different models you will find that when you get to a certain spot and squeeze lightly the problem will change or even disappear temporarily. For the more adventruous you can also try lightly twisting the casing. I've had this work on dozens of machines with similar symptoms.
Posted on Sep 25, 2007
    Problem Solver:
  • 17 Answers
Soulds like a craked screen.. needs replacement.
SOURCE:
My ibm T30 thinkpad screen is not working
It's hard to say, but if I understood correctly, your screen still functions as long as it does not stay on for a long time.
There are three possibilities
1- Video card (If you have an external monitor, plug it in and see if the same issue occurs. If so, the video card is the issue)
2- The flat cable which carries the signal from the video card to the LCD screen. (Does moving lid only (screen) causes it to behave differently? (If so, it may be the flat cable)
3- The LCD itself (In case none of the above apply)
Mar 04, 2013 | IBM ThinkPad T30 2366 Notebook
Press power button...no logo no post.just some out of focus color lines..then some horizontal flashing white lines..the battery light on the bottom of the screen is flashing and no computer boot or...
Dear user,
Good day! It seems that your laptop has hardware problem... Maybe the inverter, your LCD screen, VGA, BIOS, or even motherboard. I suggest for you to go to your nearest computer technician to diagnose it manually.
Apr 16, 2011 | IBM ThinkPad T30 2366 Notebook
I have compaq laptop, in my screen lines with colors are view in the bottom of the screen laptop is working had only one problem
lines color ? if these lines are in color red green or blue you must be change the panel screen couse yuo have brocked pixels
Jan 09, 2011 | HP Compaq Evo Notebook N600c
Colored lines appearing from bottom to top of the screen.
the LCD is a very complicating device for all CP. you may check it by disassemble it to it's LCD and connect the ribbon wire/flex of the LCD firmly... but this problem is best to replace it with a new LCD... very complicated device indeed
Jun 03, 2010 | Sony Ericsson w580i Cellular Phone
My T30 turns on but the screen doesnt work?
Try to attach EXTERNAL MONITOR to check if you have display from External Display and to confirm that your Laptop System is still working. If you got display from external monitor, therefore you have a faulty LCD / Inverter (gives your LCD a back-light)
Apr 06, 2010 | IBM ThinkPad T30 2366 Notebook
Turned on and just get vertical lines
if you have tried an external monitor to the laptop and it is still giving the same display then I think that there is something faulty with your vga or display card..Check the manufacturers website and it could be a driver issue but if not then it's time to get a new pc..unless you have the knowledge of going further..Please leave a voting for my help.Many thanks...
Jun 12, 2009 | IBM ThinkPad T30 2366 Notebook
Visual problem with laptop screen
Can you connect your laptop into another computer screen? See if that works. If so, then your screen is going bad. I would not recommend replacing the screen unless you are a harware expert. If the lines are still there try booting into VGA mode by pressing F8 at first startup. You might have a failing video card or corrupt drivers.
Apr 13, 2009 | Lenovo ThinkPad® Z61m PC Notebook
IBM thinkpad T30 Monitor
your sceen is porbably cracked.
bring to a service center nad have it replace.
Oct 29, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
322 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
