Question about Technics SL-1210 Turntable
Replacing stylus illuminator
How do you the stylus illuminator on the 1210mk2?
    Novelist:
    Champion:
  • 382 Answers
The pop up light? it's not for the faint hearted...
http://www.eserviceinfo.com/downloadsm/9858/Technics_SL1210%20/%201200.html
But feels good when you et it, let me know if you have more questions...
Posted on Oct 28, 2007
SOURCE:
Turntable hits bottom
then it's time for a new one, but the platter touches the underground: be smRt and replance the centre shaft, since you have an 1210mk2 and they need replacement. it's 40 euro. and you'll notice the difference after many years using an old one
Mar 14, 2014 | Technics SL-1200MK2 Turntable
Error code 0001002D is displayed and can not clear
Thank you for the inquiry.
This usually is a Epson Large Format printer error. You will need to replace parts to clear.
blank.gif headerline.jpg header.jpg epson_loyality.gif blank.gif menu_background_l.gif home_off.gifseparator.gifcoveragearea_off.gifseparator.gifservices_off.gifseparator.gifprinters_off.gifseparator.giftechnical_off.gifseparator.gifsearch_off.gifseparator.gifenquiries_off.gifseparator_r.gif menu_background_r.gif blank.gif 0001002D Cleaning unit EOL
Just like any other mechanical equipment, a printer requires attention to keep it running smoothly. So, just like when the check engine light illuminates on your cars dashboard so does your printer, but instead of a spanner the error 0001002D will appear on your control panel LCD which is informing you that a maintenance procedure is due to be performed. This will normally involve replacing the parts which keep the print head clean, hence the error "cleaning unit END OF LIFE" and the waste pads. This procedure can be undertaken here at Large Format Repairs for the Epson Stylus Pro 3800 right upto the beast that is the Stylus Pro 11880.
worn_flushing_box.jpg worn_cap_assembly.jpg Worn flushing box Worn cap assembly worn_head_wiper.jpg worn_carriage_waste_pad.jpg Worn head wiper Worn carriage waste pad
Jun 03, 2011 | Office Equipment & Supplies
He doesn't start anymore
I'm havin the same problem,
did u manage to work out what the fix is?
Dec 20, 2009 | Panasonic Technics SL-1210MK2 Turntable
00010020 error
try this may be it helps you --
00010020 CSIC read / write --
Just like any other mechanical equipment, a printer requires attention to keep it running smoothly. So, just like when the spanner light illuminates on your cars dashboard so does your printer, but instead of a spanner the error 00010020 will appear on your control panel LCD which is informing you that there is a problem communicating with an ink cartridge. This can be caused by a faulty ink cartridge chip or bent pins. This problem can be undertaken here at Large Format Repairs for the Epson Stylus Pro 3800 right upto the beast that is the Stylus Pro 11880.
Mar 09, 2009 | Epson Stylus Pro 9600 InkJet Printer
Fried my electrical supply...
hi aris tomas...1st check the fuse inside the turntable..then if its ok go to the main board  ..check the zener diode (D3)  and the transistor Q3 and Q2...the fidbk me wat hapen , if possible if you can chance it replace it..u
Jan 31, 2009 | Panasonic Technics SL-1210MK2 Turntable
Technics 1210mk2 turntable
Hi Dezzy
Go look here There is heaps of information on your deck. There is not alot to service, just some adjustments. If you have any problems with the T/T, got back to me here. So spruce em up and go drop some nasty tunz:)
regards
Graeme
Mar 07, 2008 | Audio Players & Recorders
Epson D88 lights flashing
Jane, contact Epson directly - if you printer is under 12 months they mat replace it
Feb 25, 2008 | Epson Stylus D88 InkJet Photo Printer
Olympus stylus 800 lens problem
Fair reasoning but I suspect incorrect.
The screen remaining black- do you mean that it shows no menu item either? or are you getting those but no image? clarify.
If you are getting nothing- is there a hint of 'shadow' images but not illuminated?
It nothing at all then this is an indication of a connector/ main board failure.
Lens not appearing could be the drive motor has stalled.
But the two items together could also mean something much easier to resolve- The battery[s] is not delivering enough power.
Clean the battery contacts. Make sure it is of the correct value as in the manual - if you have replaced it recently .
If that fails it may be new camera time as the likely cost of a repair will be high.
Dec 17, 2007 | Olympus Stylus 800 / ? 800 Digital Camera
Technics SL-1210 Turntable Logo
224 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
