Televison & Video Logo
A
Anonymous Posted on Oct 12, 2013
Model - 42LG30D-AA power indicator flashes red 3 times then is on (blue) but screen is blank it also turns off with indicator is red ....checked power supply & lead..ok. Any ideas pleas?
1 Related Answer
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Nov 14, 2009
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
My JVC Ha-s20bt doesn't want to pair with my device.. any help would be greatly appreciated. Headset pics up in my Bluetooth list but when I click on it, it asks me to pair, I click yes and then it says...
1. Check that the power is turned off
power lamp off s20_dntxilxgecvgvp-undefined-undefined-0.png 2. erform one of the following operations depending on the connection status. When connecting for the first time
Hold down button for 3 seconds until the indicator flashes alternately in red and blue.
When there are 2 or more the BLUETOOTH devices to connect to
Hold down button for 5 seconds until the indicator flashes alternately in red and blue.
3. Turn on the Bluetooth function of the BLUETOOTH device.
4. Select "JVC HA-S20BT" from the device list.
5. The indicator flashes slowly in blue when a connection is completed.
Please note :
During the pairing process, the BLUETOOTH device may require input of a PIN code. In such a case, enter "0000" as the PIN code for the System. If connection (pairing) is not completed within 5 minutes after the indicator starts flashing, the System automatically turns itself off.
2helpful
3answers
Lg tv blink codes
Take the screen off connect power and watch LEDs if any don't flash its LEDs only needed to change faulty strip if they all flash its probably t con boards.
1helpful
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
1helpful
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 • Cell Phones
Battery? console has no charge when plugged into wall outlet I push power button blue LED comes on briefly , then red flashes 3 times, and the yellow LED lights up along with the health warning on the...
What color is the power light when the system shuts off?
    Red: If the power light is red, or flashing red, when the system turns off, then the system's battery needs to be charged.
    Blue: If the power light is blue when the system turns off, then there appears to be a problem with the system and it will need to be repaired.
    If the orange recharge indicator light blinks while the system is plugged in and charging, then it is likely that the battery is not installed properly.
    If you have ensured that the battery is installed properly but the orange light still blinks, check to make sure that the battery is a licensed by Nintendo. The only licensed Nintendo DSi battery will have the model number "TWL-003" (Nintendo DSi) or "UTL-003" (Nintendo DSi XL) and will display Nintendo's logo.
    Call 1-800-255-3700 if you still need help.
Hitachi projection tv quit
Pls check that model number........the problem description does not match that of a 1999 crt proj tv.........I believe yours is a newer lcd projection around 4 or 5 yr old?? Lamp light flashing on any brand is indicative of the lamp not lighting . The lamp is the most likely cause,but the ballast board can cause this as well..................you should see an access door refer to owner book of the correct model and you can replace yourself...........it may cost around $200 and avaiolable at encompass parts .com Hitach distributor
13helpful
2answers
Tv is blank when turned on
Do you have a green light that flashes and then goes off? You need instalation kit# 4835 310 57673, The chassis# is probably an L04.1U AA, correct? What you will do is correct the horizontal timing so everything will come on at the same time. After you install you will see red, blue, and green horizontal lines at the top of your screen.......this is normal when you power up your TV. This is a factory authorized repair.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
