Question about sonoro Cubo Clock Radio
Sonoro cubo reset i have a sonoro cubo AU1100 -
Sonoro cubo reset i have a sonoro cubo AU1100 - it is not possible to adjust treble - tried to reset (turn of -> on standy ->
    New Friend:
I have the sonoro cubo too ad meet same issue. I think the inside microprocessor cab be wake up.
Posted on Jul 09, 2017
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
Resseting the Clock, I had to cut the battery cables and rewire them, bu i dont know how to reset the clock
Keep pressing the knob that you use to adjust bass, treble, fade, ect, keep going, you will get to clock. Next one after clock is set the clock. Then you have to be quick about it, turn that same knob to increase or decrease the hour, then it will move to minutes and turn till you get the right minutes.
You really have to be quick about it, it took me several times before I got it completed.
if anybody has the 2.5S model 2010 Altima >>> hold the Clock button for 2 seconds, when the words SEEK and TUNE appear, press the Seek button (top LEFT) up or down to change the Hour ... then press the Tune button (top RIGHT) to change the minutes ... press Clock again to end adjustments.
Jul 13, 2011 | 2000 Nissan Altima
Jvc hd-61Z786 REAR PROJECTION TV . is dark. replaced the lamp. did not help much
all u have to do is to
Reset Picture and Sound Adjustments
1.Press the "Menu" button.
2. Press the "CH+" or "CH-" button to "Reset" listed on the display.
3. Press the "Volume+" or "Volume-" buttons to move left or right to enter your Reset selection. The Reset will reset all of your picture adjustments, including the color, brightness and tint to the default settings. Reset also resets your sound adjustments to the default settings, like the balance, bass and treble.
4. Press the "Menu" button to complete the resetting process
Feb 23, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
pressed:
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
fader.
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
a.
4) To.store the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
How do you adjust bass treble front and rear parameters? have no manual
With the radio on, try pressing the right round knob, each press will select another function, that you can then adjust by turning the knob.
Try downloading an electronic manual from Jeep's website...
http://www.jeep.com/en/owners/manuals/index.html?year=2006&nameplate=Grand%20Cherokee
Oct 07, 2009 | 2006 Jeep Liberty
Can not turn the bass and treble up or down on my alpine CDA-9827
ok i cant see your entire question but to adjust bass and treble on an alpine, you see the knob (the one which u use to turn volume up and down), push it in (itll click) then a screen/textt will come up and say bass or an option once it says bass, turn the knob up or down, then press in again and it will say treble or fader or something else, once again, adjust it and keep pressing in the knob until u reach the volume again. does it work? is this what u wanted?
Apr 11, 2009 | Alpine CDA-9827 CD Player
Adjust
I have an Alpine CDA-9813 and to access bass, treble, fade, and balance, you need to press the volume button. This button is usually rotated to adjust the volume but on mine, if you press it in, first time accesses bass, second press accesses treble, 3rd press accesses balance(left to right), and 4th press accesses fading (forward to rear. Press it a 5th time and it either brings you back to volume or back to the main screen. I think it is volume tho. I would assume that the 9853 would work very similar, if not the same.
Mar 21, 2009 | Alpine CDA-9853 CD Player
Sony radio cdxgt210
Use the main control knob. The one that turns your volume up and down. If you press it in it should go through bass, treble, fade, balance, and sub. Then use that same knob to adjust it by turning it left or right.
Jan 20, 2009 | Car Audio & Video
Help front panel wont work and treble +10 keeps coming up by itself
Check all of the push buttons on the front panel.. I have seen that sometimes a switch could have gotten jammed or pushed an and broken and the button gets stuck and wont let anything else work
Sep 21, 2006 | Yamaha HTR-5650 Receiver
sonoro Cubo Clock Radio Logo
168 people viewed this question
Top sonoro Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a sonoro Audio Player and Recorder Expert? Answer questions, earn points and help others
