Question about Canon PIXMA iP4200 InkJet Photo Printer
Error 5400 - Internal temperature error
I'm not sure how this happened but all I know is that my printer was barely new. First I tried to turn it off and on again but that didn't work. I tried it on other pc's and the error was there again. Thank you
    President:
  • Canon Master
  • 2,022 Answers
Just switch it off and wait for 10 minutes then again swith it on and see
Posted on Sep 25, 2007
Error codes and their meaning
Here are a list of error codes that you may come across on a Canon printer.
If a part is faulty and you are unable to repair yourself, then contact the provider or local service centre.
Error B200
View information.
Error 306
View solution.
Error 5011Get the printer repaired by the provider or manufacturer.
Error 5100An error occurred in the carriage encoder signal.
Error 5200
The print head is overheating.
Turn the printer off to allow it to cool down and turn it on again but seek repair if the problem persists.
Error 5400
The internal temperature is not what it should be.
Error 5700
The sheet feeder needs to be replaced. It can be that the gears in the printer and/or sensor have become faulty.
Error 6000
An error occurred in the LF encoder signal.
Can be the result of a deep paper jam with pins, paper or other miscellaneous objects stuck in there.
Error 6A00
The cartridge mechanisim is jammed.
Error 6A80
View solution.
Error 6C10
Reset the ink absorber.
Nov 07, 2013 | Canon PIXMA Office Equipment & Supplies
Error code 5400
This error related to the internal temperature being out of normal range. If the printer has been used for high volume printing recently then simply unplug it and let it cool down.
If this does not help then replacing the printer is much cheaper than a repair job!.
I hope this helps
Regards GM
Apr 10, 2011 | Canon PIXMA MP510 All-In-One InkJet...
My print is Canon MX320. I just changed a new ink, but the error 5200 occured. Do you know what happened? Thanks.
Error 5200 indicates that the print head temperature has exceeded the specified value. Turn off the printer and then turn on, if error still persist replace ink cartridge or print head.
Jan 30, 2011 | Canon Office Equipment & Supplies
My mp160 appear error e2 and e16 pls solve it.tq
Carriage unit (main unit)
Timing **** strip film
Logic board ***'y
Carriage motor (main unit)&
Internal temperature rise error [5400] - Logic board ***'y problem
Oct 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error 5400 in my Printer Pixma MP 610
5400 is a temperature error that points to a new logic pcb, but the other day I had one that was caused by a bad printhead. If you can get it out, try powering up without the printhead installed, if it's bad, the error will change to no printhead and you can just pick up a new one.
Sep 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error 5400
5400 is an internal temperature error that usually shows up when the main logic board goes bad. The price to replace it is probably more than a new printer.
Aug 15, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Error 5400? what is the problem and how do i fix?
the 5400 error is telling you there was excessive temperature in the printhead, and this error code will stop all printing attempts.
Unplug the power from the printer and leave it off for a hour and then check the pins inside the carriage and clean them and clean the contacts on the back of the head.
Jul 19, 2009 | Canon Office Equipment & Supplies
Canon Pixma ip3000 flashing amber 6 times
If the 6 flashes are accompanied by an on screen message #5400, this is a "Service Call Error" code.
This code indicates the following;
Internal temperature error [5400]
The solution to this is the following part replacementl
- Logic board ***'y (QM2-1548) *1
*1: Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or
more, also replace the bottom case unit (QM2-1205) or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257) when replacing the
logic board ***'y.
[See Section 3-3. Adjustment / Settings, (6) Service mode, for details.]
Good luck!!!
Jan 12, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Error code 5400
go online and type in following information"
canon printer errors code 5400
enter
rod
Dec 22, 2008 | Canon CLC 1150 Color Copier
Error 5400
May 31, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA iP4200 InkJet Photo Printer Logo
243 people viewed this question
Clive
Clive
old marine
old marine
