Question about Vacuums
Electrolux ultrasilencer will not turn L
Blinking L
3 Suggested Answers
SOURCE: I have an Electrolux Ultrasilencer Deepclean
check the Fuse of the unit and see if replacing it will fix the issue.
Posted on Aug 10, 2011
bugoy31
  • 1238 Answers
Good day!!!!
that problem and faulty codes is cause of overloading due to difficult spinning of motor that usually cause of lock on lubrication...Please try oil the motor...
If you have any clarification and query regarding my solution...Just add a comment and I response you as soon as I read the comment..
Thanks for using fixya...
Posted on Aug 12, 2011
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Electrolux Ultra Active ZUA3840 error blinking L (or 7)
Sure, Disconnect the two wires going directly to the motor. Then apply line voltage directly to the motor terminals. If motor does not turn it is defective - check the brushes for wear or bad contact. If motor runs then the electronics are bogus.
Nov 28, 2013 | Electrolux Vacuums
Electrolux ergorapido plus
Christmas 2013 I was given an Electrolux ergorapido. I put it on the charger and red light won't come on or if it by chance does it flashes three times and then cuts off.
Aug 13, 2013 | Vacuums
Cord won't stay out, it keeps going back in
when pulling the cord out, it should 'keep' it that spot if you pull a certain direction, cant recall if it is up, or down, left or right, and pulling it opposite direction releases the cord again
Mar 10, 2013 | Electrolux EL6984A UltraSilencer Green...
Green canister lid wont close
http://smallappliances.electroluxusa.com/en-US/Customer-Support/
download free your instr manual and see your problem lid why not close, go to the section troubleshooting.
God bless you
Sep 27, 2012 | Electrolux Ultrasilencer Green Canister...
How to clean a washable electrolux filter
Hi There,
Ok so i am going to assume you are talking about an Electrolux filter that is basically a rectangle shape with a hard plastic outer and folded corrugated filter material in the middle. The link I put to Electrolux filter would be a good example. Basically I would caution you against washing it. I know the packaging says that it is washable but what I have found is that the pores of the filter material are too fine for water to pass through. What will happen is that the vacuums suction will wedge tiny bits of dirt and dust in the pores and water will not necessarily flush it out. What is far more likely to happen is that it will wash out a fair amount but leave a portion in the filter to set and therefore continue to block suction.
You are better to use an air compressor or simply tap the filter out on a piece of newspaper and change it every year or so.
Of course if your filter is more like a Electrolux UltraActive filter which is basically foam then you simply rinse it out like a kitchen sponge and make sure it is bone dry before putting back in the machine.
Jun 26, 2012 | Electrolux Ultrasilencer Green Canister...
How do I take apart my electrolux ultrasilencer green vacuum to fix the retractable chord?
I would not recommend doing that. Take it to your local vac shop. They may or may not be willing to repair it. These machines were not built to repair. They are considered disposable. I have repaired these at my store but it is a very tedious task to get it apart without breaking all the tiny plastic tabs. You should give the local shop a chance before trying it yourself. They are better equipped for it.
Jan 08, 2012 | Electrolux EL6984A UltraSilencer Green...
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
Vacuums Logo
396 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
