Question about Dryers
Getting the heating element casing back on to the back of a Kenmore elite dryer Model#11063942101
I have a Kenmore elite dryer model # 11063942101 how do i get the element casing back on to the back of the dryer?
  • Anonymous Mar 25, 2014
    model# 11062066102 I need the heating element for this model
  • 113 Answers
There are slots in the casing that slide down on tabs comeing out of the dryer. put the top part of the casing in then put the bottom part in and slide down on the tabs
Posted on Apr 23, 2009
Kenmore dryer he4 elite dryer not heating model #95862402
using multi-meter need to check the heating element and the thermostats for continuity. you are getting a full 240 volts at the outlet right? if only 120 then u will be able to run the appliance but not the heating cycle.
Sep 25, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore elite , no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
Drum turns, no heat
either the heating element or the thermal fuse very worst case would be the timer but i have all parts in stock whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 63942 Dryer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Kenmore Elite dryer won't heat but otherwise operates normally
Make sure you have 220V. The dryer will work (no heat) if only getting 110V. Check your thermostats with your Ohm meter. Mkae sure plug is disconnected and you disconnect thermostat wires. Should have continuity. Just because you have checked your heating element and you have continuity that does not mean it is good. How can this be? Easy, sometimes they (coil in heating element) break and arch against the housing or ceramic insualtors (depending on model) and you will have continuity. This just happened to mine and without a visual inpsection of the heating element do not aaume it is good.
Jan 07, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Need manuals
What problem are you having, the problems i have seen with kenmore elites are below.
1. when you press start and release dryer shuts off
for this problem, change the board in the console
2. not producing heat
for this problem, check to see if 220 is getting to element, check to see if you are getting 220 from outlet, check your thermal cutoff on heating housing, check your heater relay which is located in top console.
Apr 02, 2008 | Kenmore 63942 Dryer
Dryers Logo
185 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
