Question about Dualit 25375 2-Slice Toaster
How to remove base plate in order to replace element
Where can I purchase a tool to remove the bottom panel of the toaster. It appears to be fixed with very small hex head screws
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
juliant61
SOURCE: Dualit combi heating element 12/95
All the element's are available on e-bay u.k. for about 6.00 gbp. Alternativley you may be able to repair it. Put the toaster on it's side with the bottom facing towards you and the knobs on the top. Remove the crumb tray and then remove the bottom (usually the screws are located in the feet). There may be one more visible screw remove that too, then you will see a rail at the bottom that secures the element's in place. Loosen off the nuts at each end and slide the rail down, undo the two bolt's feeding the power to the element's and slide the element out.Go over it with a continuity meter and see where it's broken then move the element wire about to bridge the circuit.Test it again and reassemble. I repaired mine this way.Or, simply replace the element using the instructions above.Easy!
Posted on Nov 30, 2008
espressonist
  • 1711 Answers
SOURCE: I cannot get the plate off the bottom of my dialit
Their not any special tool. It probably stuck because of burned bread or other stuff meld and this blocking the plate to be removed. You can use a plyer and extreem force and even you can use a cutter to cut the plate in some places so it can be removed since you dont need anymore.
However this need a special skill in order to avoid any otherdamage of the toaster.
Good Luck
Posted on Apr 02, 2010
espressonist
  • 1711 Answers
SOURCE: How do you replace a centre element of a Dualit 3 slice toaster?
You can buy the elements from ebay uk and for 110 v also, they are so slim and light that they ship them in normal envelope and arrived in no time.
You can follow the instruction in the link what to order and how to replace.
We have the procedure here in this link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
Good luck
Posted on Aug 20, 2010
espressonist
  • 1711 Answers
SOURCE: Dualit 4 slice toaster.
Yes correct
Posted on Sep 01, 2010
The coils (heating) do not appear to be working Tost comes out warm but not brown!!!
Inside your toaster there are four heating element plates two in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Mar 27, 2010 | Dualit 20247 2-Slice Toaster
Not toasting evenly
Inside your toaster there are six heating element plates four in the center and one in left end and one in right end.
Remember that the four in center are the same called "CENTER" and the other two on ends are the same called "END"
Good Luck
Mar 26, 2010 | Dualit 31210 3-Slice Toaster
The heating elements don't come on.The timer is working as you can hear the clicks but that's about all.
We had the same problem. I took off the bottom plate, cleaned the toaster, reseated all of the connectors on the heating plates, timer, and switch, and the toaster started working again. Only one connector was slightly loose (but it was still connected with decent contact). I am not sure what fixed it. If that did not work, my next step was to purchase replacement parts online and swapping out the switch, timer, and heating plates (in that order).
Feb 11, 2010 | Dualit CTS4E 4-Slice Toaster
Recently it has taken longer and longer for pieces of bread to toast. Additionally, the plug seems unduly warm. Do the elements need replacing?
Good Luck
Jan 10, 2010 | Dualit Vario 3 Slices Toaster
The center panel of my 2 slice Dualit toaster is not heating. Can I replace it?
Good Luck
Jan 06, 2010 | Dualit Vario 2 Slices Toaster
One of the elements does not work
Good Luck
Jan 02, 2010 | Dualit 20247 2-Slice Toaster
I think the elements are no longer working. can these be replaced or fixed?
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red. They can not be fixed.
Good Luck
Nov 29, 2009 | Dualit Vario 3 Slices Toaster
I need the elements replacing
Good Luck
Nov 21, 2009 | Dualit Vario 3 Slices Toaster
All slots not heating
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Good Luck
Nov 16, 2009 | Dualit Vario 4 Slices Toaster
The toast gets done on one side and not the other
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Good Luck
Jul 12, 2009 | Dualit CTS4E 4-Slice Toaster
Dualit 25375 2-Slice Toaster Logo
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
