Question about General Electric DHDSR46EGWW Dryer
Have power to it but nothing works
Pluged in dryer and nothing happens checked power and is all wierd right have power to all the controls on the top but nothing happens
  • jchrist99 Apr 23, 2009
    tested the swich it is bad. geting a new one now thanks.
  • 113 Answers
Check to see if the door switch is bad
Posted on Apr 23, 2009
CL error code appeared during cycle
make this test and fix it. Merry Christmas
Power From The House
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the switch
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replace the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Main Control
The main control board may have failed. To check this check the two main feed leads entering the control refer to the tech sheet located on your dryer. The two leads are usually a separate plug of heavy wire. Check to see if power is entering you should have 120 volts. If not the problem is not the control. If you have power coming in and nothing is illuminated the main control faulty, replce or the Timer will be replace
Dec 17, 2013 | Kenmore 4.3 cu. ft. High-Efficiency...
Dryer power is on. When I set the cylce and push start nothing happens. Already checked the belt and it is fine.
Have you check go see it you are getting a full 220v to the dryer, assuming it's electric. If there's only one leg of the power the control power would come on, but nothing else would work.
Apr 09, 2011 | Kenmore Dryers
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Having problem with my Electric Maytag. I push the start button and nothing happens.. The model bumber is pyet344ayw..
Have you checked the circuit breaker? I would start there. Dryers run off 220v, and sometimes only one leg of the breaker trips. so you need to flip the breaker all the way off, and then back on. sometimes the breaker feels off when it's not. make sure you completely trip it off then back on. Does the dryer light work? is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service tech.
Sep 20, 2010 | Maytag Dryers
I've got no power to the control panel. Try to
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 06, 2010 | Amana NDE5800AY Electric Dryer
Loss of power to the display
Dryer Repair ? The dryer will not start
heatman101
May 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My whirlpool dreyer does not work. power turns on
It has a bad Thermister. you will need to chage it. it is right on top of the blower housing
Jan 20, 2010 | Whirlpool GEW9250 Electric Dryer
Kenmore electric dryer
ck door switch also ck connection of power cord could be burnt remove back (if top mount filter lower panel if door mount)look for white thermal fuse ck for closed circuit through fuse fuse is in motor circuit and has been known to blow for pluged or restricted vent system
Jun 10, 2008 | Kenmore Dryers
My dryer doens't start up
Depends on if you can hear any noise when you hit the start button or turn the knob. If there is a hum or some sound then could be belt or motor problems. If there is no sound dead, then you are checking the right area, there are kill switches in different places on dryers. one is like you checked the door switch, and another may be in back when you open the cover to check. Maybe fallen out of place. These sw. are for your safety and sometimes they malfunction. Hope this help!
Aug 12, 2007 | AEG T57800 Electric Dryer
General Electric DHDSR46EGWW Dryer Logo
170 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
