Question about Oreck pro12 commercial upright vacuum, 12in,8a,120v
My Oreck pro12 make noise , I thought something was inside, I clean all pipe, but noise is very loud and does not clean any more
More than likely needs motor replaced.
Posted on Nov 08, 2013
Pro12commercial won't turn on
Probably a short in the wiring, a bad switch, or you could have a wire that has come loose from it's connection. If you have access to a multimeter, I would use that to work your way through the vacuum to see where the fault is located. Good luck!
Oct 22, 2014 | Oreck PRO12 Commercial Upright Vacuum,...
Sensor goes off when you hit a wall
it is probably because you are not supposed to hit the wall with the vacuum you are hitting the power switch which shuts the cleaning unit off
Mar 18, 2014 | Oreck pro12 commercial upright vacuum,...
Vacuum motor screaming
look at all the pipe and unblock them
Dec 25, 2013 | Oreck Vacuums
Sparks coming from under oreck vacuum. looks like its coming from motor brushes.
Probably need to have that serviced at a repair shop. They can tell you whether or not you need a new motor or a fan blade kit.
Feb 21, 2013 | Oreck XL Ultra Bagged Upright Vacuum
There are sparks coming from the underside of my oreck xl vacuum.
You probably need to take that in and have it serviced at a repair shop. They can check the motor to see if it needs to be replaced or just cleaned. The noise could be bad bearings or a fan problem as well.
Feb 21, 2013 | Oreck Vacuums
The bag won't stay on in the bag container
I thought my Oreck upright vacuum was broken because the bag wouldn't stay on. Even worse, when the bag popped off, I couldn't figure out how to get it back on. There was no satisfy 'click' or any other indication that the bag was installed properly. A good percentage of the time, it wasn't actually installed properly, and the dirt just collected in the space between the bag and the bag holder. (The easiest way to recover from this messy situation was to vacuum out the Oreck with another vacuum! When I do this, I can't help but think how embarrassed the Oreck must feel to be humilated in this manner . . .)
Anyway, after a trip to the Oreck dealer to purchase a replacement part for what I thought must surely be a broken bag-holder assembly, I now know that it's the design itself that is defective. After all the money we paid for the Oreck, my wife won't let me get rid of it. So I just use the cannister vac we got for free with the upright and spot vacuum instead. (I'm seriously thinking about breaking something inside the Oreck so my wife will let me throw it out and get a new vaccuum. We bought a new vacuum recently to use at our vacation cabin for a fraction of the price and it's a joy to use compared to the Orec - it was a Consumer Rerports "Best Buy".)
Feb 06, 2011 | Oreck XL2200 Bagged Upright Vacuum
Loud rattling noise.
Hi there SmartAlec from NelsonVacuums.com.au here. Often when an upright is making a rattling noise it can be something caught in the roller and every time the brush turns it knocks against the body and since it turns really fast it can sound quite bad. Take the roller out and clean inside that area and see if that helps. Hope it does. Happy Vacuuming :)
Aug 03, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Oreck Vacuum troubleshooting
Hi. If the motor is on its way out the motor noise will be eratic eg slowing down speeding up popping noise & a smell of electrical burning. If you have none of these symptoms then chances are its not the motor. Does the bag inflate or is it easy to collapse when you push the bag ? If bag inflates ok check belt. If bag not fully inflating check for blockages along length of the handle pipe its designed to pull apart by lifting up rubber sleeve at machine end of pipe, push ball latch in & pull pipe out remove any debris stuck in the pipe. Remove bbottom of machine as if replacing belt check to see if there is any debris stuck in the oppening that goes to motor fan, then check the fan blades you can see them through the port is there any missing or snapped off. If blades are missing or have big chunks missing you will need to replace. If fan only has minor bits missing then reassemble it should now worl well.
Sep 07, 2007 | Vacuums
Oreck Vacuum Cleaner problem (upright)
The best solution to any Oreck vacuum problem is to replace it with another brand. You are going to continue having problems with the Oreck..Not that other brands don't have problems. But, at least with
other brands the problems don't occur as often. Belt burning up. clogs, roller brush bristle wearing down prematurely, cord breaking internally, etc.
P.S. Oreck is good at one thing. Marketing!
Aug 30, 2007 | Oreck XL2200 Bagged Upright Vacuum
Oreck pro12 commercial upright vacuum, 12in,8a,120v Logo
139 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
