Question about Health & Beauty
Mainstays digital kitchen scale manual
Weighs grams & ounces up to 10 lbs
  • 10 Answers
SOURCE: Instruction manual
I would at this point return to the place that you bought the scale or some place that sells the same one you have and buy it and then photo copy manual. Then take your reciept and the scale and go get your money bac! Good luck.
Posted on Nov 24, 2009
  • 279 Answers
SOURCE: New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Posted on Jan 17, 2010
SOURCE: Have a Chefmate digital stainless steel scale. It
Easy! On my Chefmate scale what I have to do is toggle so that "weight" is blinking. Then hit "0" - that is zero. Now you can change back and forth from grams to oz!
Posted on Jul 31, 2010
  • 16 Answers
SOURCE: My scale adds anywhere from
there should be a dial on the sides to zero it out. if it doesnt, then it has something to do on the actual scale. does it have a menu or settings option? you should be able to zero it out.
Posted on Dec 10, 2010
fb62685
  • 4 Answers
SOURCE: I just bought I digital
I had already solved this after a lot of playing and research, put I thought I;d post it on here for others as the answer was different for other scales listed here. What I did was press the 'Button 1' and 'Button 2' together for 5 seconds. This powered it up and then the display showed 'Cal' with a number on the screen. I pressed 'Button 1' again and it said 'Zero' and then displayed the numbers '0000'. Then I added 1kg of weight and it said 'Cal1'. Then I added 3kg of weight. It said 'Cal2'. Then I added 5kg of weight. It said 'Cal3', then 'Pass'. It then returned to normal mode and now started weighing correctly. I calibrated the weights (Flour and Sugar packs) on another set of scales first, but they were only a few grammes wrong so would be close enough anyway. I hope that helps!
Posted on Dec 04, 2012
Salter high precision stainless scale 1078ss. How do i get it to weigh ounces
Put the weight on the scale. It should weigh ounces, pounds, grams, and killograms, all in the same unit.
May 12, 2017 | Salter Health & Beauty
How many cups is 100g?
Here is how volume/weight conversions work. A gram is a unit of weight. A cup is a unit of volume. Volume is the amount of space an ingredient occupies and weight is the mass or "heaviness" of an ingredient.
500 grams of mini marshmallows = 10 cups
500 grams of flour = 4 cups
500 grams of sugar = 2.5 cups
As you can see, the weight for these ingredients are the same, yet the volumes are different. This is because each ingredient has a different density.
Here is another example:
A cup of feathers and a cup of lead pellets both occupy 8 fluid ounces of volume. The feathers will weigh a lot less than 8 ounces on a scale and the lead will weigh a lot more than 8 ounces on a scale.
Asking how many cups equal 100 grams would be the same as asking how many hours are in a 100 inches. Volume and weight are two completely different measurement systems... just as time and length are two different measurement systems. The only difference is that volume and weight can be linked through density.... mathematically speaking. Density = Mass divided by Volume. Density can change for the same ingredient. For example, a cup of sifted flour will weigh a lot less than a cup of unsifted flour. A pint of water will vary in weight depending on the temperature of the water.
There are websites that do volume/weight conversions based on density. Two great websites are:
http://www.onlineconversion.com and
http://www.gourmetsleuth.com or, you can look in a cookbook that has a volume/weight equivalency chart.
Apr 15, 2015 | Ice Cream Makers
Weight of a gram of sunflower seeds
A gram of sunflower seeds weighs exactly one gram or one-thousandth of a kilogram.
If you want the Imperial equivalent there is about 28 grams to the ounce so one gram will equal one twenty-eighth of an ounce.
Measuring such small weights requires a different measuring scale and the apothecary measures are appropriate: the dram is one sixteenth of an ounce.
For rough measure purposes one gram is about a quarter of a dram.
For exact purposes all the conversions can be found by google.
For practical purposes it would be better to measure out one ounce, one half-ounce or one quarter-ounce of seed whichever can be done most accurately and then divide it by eye into 28, 14 or 7 equal portions in order to obtain approximately one gram.
If greater accuracy a chemical balance would be required.
Feb 26, 2015 | Birds
How do I switch from grams to ounces on the Polder kitchen scale?
There is a button on the back of the scale with "g/oz" below it. This changes your scale from grams to ounces or vice versa.
Feb 24, 2015 | Polder Slimmer Digital Scale
Have a Chefmate digital stainless steel scale. It weighs in grams and ounces. It was changed accidently to grams but I want it in ounces. Not sure how to do it and misplaced owner's manual.
Jun 25, 2010 | Microwave Ovens
ONE TROY OUNCE EQUALS HOW MANY CUBIC INCHES? Another way - how large is a troy ounce of gold?
1 troy ounce =31.1035 grams
454 grams = 1 lb
gold weighs .3091 lbs/cubic in
therefore 1 troy oz = 0.2216 cu in
Apr 04, 2009 | Office Equipment & Supplies
Health & Beauty Logo
2,057 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
