Question about RCA RT2910 Theater System
This unit will "freeze" and the sound will not work. We are unable to even shut the unit off and therefore unplug it. It will work again for a period of time but then will do the same thing... But then it won't happen again for a couple of months. I just recently dusted and vacuumed the unit and area after this problem began again but now it continues. Any suggestions?
3 Suggested Answers
  • 556 Answers
SOURCE: tv not powering on
as per your statement there is a loose contact in power supply section of your tv. it is 1oo% sure that allthe parts are ok as tv runs ok when it comes on. but you will have to call tech. as without knowing technology it is dangerous to open tv due to high voltage.
Posted on Sep 15, 2007
  • 8 Answers
SOURCE: Unit just gets stuck at Hello sign.
You have a blown capacitor in your machine. If you are good with a soldering iron, great, you can fix it yourself. Otherwise, find a friend who is good with a soldering iron. Parts should cost you less than $2 for a new capacitor. Replaced the blown capacitor in my machine, and my tape popped out with no fuss once I powered the system back up.
Posted on Mar 14, 2010
Feezer shut down with hi-temp alarm
Sounds like a defrost problem. Water came from frozen evaporator that thawed after being unplugged. It will operate great until evaporator freezes over again because it's not defrosting. Defrost components are defrost timer or Board, defrost heater, and defrost thermostat. One or more of those components have most likely failed. Also be sure Freezer / evaporator fan is working.
Aug 29, 2017 | Refrigerators
Unit freezes at the loading maps stage
Yes! Yes! The exact same thing is happening to my nuvi 1300 right now one month after yours. What did you figure out? Can someone help? I've also tried to do the clear the device by pushing the right hand corner of the screen while powering on and I do not get any sort of 'would you like to clear everything?' message that I'm suppose to get. I'm going to check into battery recall that I heard about, but I don't think it's for the Nuvi 1300. Someone help! A :)
Jul 26, 2010 | Garmin GPS
GE side by side Model GSS25JFMD 2 yrs old. Original problem was not staying cold. now I see if I unplug for half hour it seems to work right but sometimes freezes in fridge . I'm hearing a clicking sound...
Looks like a thermostat problem. The condensor is running but unable to stop when it should. It is the thermostat that should shut it off.
This is a very sophisticated fridge/ freezer and with electronic controls.
There is not much diagnostic you can do yourself other than replacing parts. If you are not comfortable with this type of equipment you should call the professional.
Good Luck.
Feb 27, 2010 | Microwave Ovens
2 weeks ago one of my units stopped working properly. It got warm during the night even though I heard the unit running. I shut it off and called for repair service. They changed the thermostat and it...
sounds like the coils inside the air handler/furnace are freezing up. likely cause is the freon charge is incorrect (probably undercharged). it may have been correct when the tech did the work but some may have leaked out. it is slightly possible too that the system is overcharged. you should have the system pressure verified, and then have it checked for leaks.
Jun 16, 2009 | Goodman CLJ36AR42 Air Conditioner
Intermittent reminder beeper won't shut off
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
May 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Pipes frozen on outside of unit, inside unit does not work
sounds like the compressor relay is stuck in the 'on' position .... hence the compressor will not turn off .... to fix it you will need to turn off the main power (unplug) and take off the front panel then look at the circuit board normally the largest relay on the board is the compressor relay ... sometimes you can snap off the cover or break it off at times and clean the contacts ,give it a little spray with some contact cleaner or lub like wd 40 and that should be it .... alternative to this is just changing the circuit board all together ....
May 19, 2009 | Mitsubishi Heating & Cooling
MY GE PROFILE REFRIGERATOR IS WARM, FREEZER IS FINE.
i think its not the frz drain hole blocking up but a fault with the defrost tray heater. the tray heater should keep the defrosted frost as water to drain away. it sounds as though the tray heater is not working therefore letting the water freeze as it is escaping thorough the drain hole. i would check this out by defrosting the unit and inserting a flexi rod into the otherside of the drain hole (above the compressor usually) and after clearing it if it freezes up again check out the defrost/heater system.
Apr 08, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Pb10-cd
You're welcome in advance.
This particular unit was advertised to be unbreakable when dropped due to its shock absorbers; therefore dropping it will fix it.
Oct 24, 2007 | Bosch PB10-CD Radio/CD Boombox
Hums and freezes up????
The fan motor must have been stopping. If the fan stops, for sure the fins will freeze because there is no air flowing. common Fan motor problems defective bearing or bushing and starting condenser. If the bearing is defective, it will heat up and seize. Have the fan motor checked. The fact that the fins are freezing, means that there is enough freon and the compressor is working.
May 29, 2007 | Frigidaire FAS155K1 Air Conditioner
RCA RT2910 Theater System Logo
41 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
