965gdag lf hi there i have a FF problem showing on my boards led display board wont start up fans workin keyboard works but no display or bootup. Display card working and ram ok. Cpu working to all tested on another board. Can anyone help please?
    Sergeant:
  • 240 Answers
Go to your manual that came with the motherboard (mobo) and look up the FF post and what it means. If you don't have a manual go to the manufacturer's website and hope that they posted one in the Downloads or Support section for your computer.
OR go to your computer manufacturer's website and do the same thing, only look up the model number of your computer.
If still no help, go HERE, log in and post your question in the Hardware section of the forum. Lots of knowledgeable folks there to help.
Posted on Oct 13, 2013
jackboy
  • 2985 Answers
SOURCE: The error code is " 0 " with PC Analyzer PI0049F
I think this model needs extra 12v in a 4 pin connector to run the processor. The CPU will need to be cabled for it or an abaptor can be had. Check your manual
Posted on May 17, 2007
SOURCE: ASUS STRIKER FORMULA
cheddar
Posted on Mar 10, 2008
nai6378
  • 58 Answers
SOURCE: AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
Posted on May 10, 2008
SOURCE: No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Posted on Jul 05, 2008
  • 3 Answers
SOURCE: My ASUS P5SD2-VM Is Having A No Display Problem
Pls check the moniters cable. otherwise chek the display device in motherboard
Posted on May 20, 2009
My kenmore upright freezer has a digital display that shows alarms. it is showing a ff and a ce code. can you tell me what they mean?
You have a bad freezer fan and need to replace it. The fan is located behind the back wall INSIDE the freezer. The unit will warm up a little because the air wont circulate the way it is supposed to. You can try unplugging fridge for 30 seconds to reset the control board u can do it yourself although I don't recommend it because u need actual diagnosis but this seems it hope it helps try buying part from sears or amazon
Dec 10, 2013 | Kenmore Freezers
My ASUS M4A785TD-V EVO having problem. after starting pc its not showing display. but processor fan and cooling fan. board led is working. and while starting there is no beep sound .. i am not...
Hi ,
Some short circuit took place somewhere . Have your pc controlled by a qualified technician . Ask for specifications before repair .
Best regards ,
fanaudi .
Sep 04, 2011 | ASUS M4A785TD-V EVO Motherboard
LFC 25760St Refrigerator displaying a code FF Er what is going on
Er FF code is a freezer fan motor error. Check too see if there is a loose connection to the freezer fan. If not you may need a new fan motor.
Oct 07, 2010 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Display reads er and ff
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 30, 2010 | LG LRSC-26922 Side by Side Refrigerator
LG display error code FF IF
The FF error code is the freezer fan motor error. It could be a problem with your freezer fan motor or an issue with the control board not sending proper power to the board. If you remove the back panel you can check to make sure there is no ice restricting the fan motor from turning. If there is ice then check the icemaker fill tube and make sure its in place properly and not leaking down on the evap fan blade.
Hope this helps _MJ_
Feb 07, 2010 | LG LFX25960 Bottom Freezer French Door...
New P5P43TD PRO. Will not bootup. No diplay at
Hi shipale,
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck
Mark
Nov 14, 2009 | ASUS P5P43TD Pro Core 2 Quad/ Intel P43/...
Server board SE7591BR2 wont run
did you connect the internal speaker to listen to the bootup beep code?
Jul 31, 2009 | Intel Server Board SE7501BR2 Motherboard
Possible defrost problems
THEM MAIN PCB AND FAN MOTORS . SHOULD FIX THIS BROPLEM . TGHEY UPGRADED THE RELAYS IN THE BOARD .WITCH SEEMS TO WORK . THERE MIGHT BE SERVICE FLASHES OUT THERE WITCH WOULD COVER THE COST
Jan 13, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Gigabyte mother board ga-6bx7+
You might have damaged the CPU/ motherboard during the process of overclocking.
Check your CPU on other compatible mobo.
Check your mobo documentation properly & set the jumpers rightly. If that doesn't help, you will have to replace the mobo.
Jul 01, 2008 | Gigabyte GA-6BX7 Motherboard
Fan in the freezer stop working ater a while
You may have a serious issue with the wiring harness inside the refrigerator.  You will need to have the technician come back out and check the continuity of the wires leading from the control board to the fan checked out.  If there is no continuity, it is not repairable.
Mar 13, 2008 | LG LRSC21935 Side by Side Refrigerator
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
