Question about Miele Inspira Series Dishwasher w/ 6 Programs and 5 Temperatures - G2120 / G2120BL - Blac 24 in. Built-in Dishwasher
Intake drain - Miele Inspira Series Dishwasher w/ 6 Programs and 5 Temperatures - G2120 / G2120BL - Blac 24 in. Built-in Dishwasher
How do I fix a Miele G2470 SCVi with an intake/drain fault
Look for item(s) blocking the drain, inside bottom, and remove them.
May 24, 2014 | Miele Dishwashers
Miele 863 sc will not run a cycle, it just hums and says check intake drain which we have cleaned and checked all drains and screens
Something may have made it past the drain, is now stuck in the pump or its' intake. Put a tray under it and remove the drain connection to the pump. Unplug the unit first.
Nov 30, 2013 | Miele Dishwashers
My intake/drain light is on. I have run my garberator. What else should I do to try and fix the problem?
A flashing "Intake/Drain," means something is wrong. It doesn't necessarly mean, "no water coming in," or "poor drainage." But of course, we should check those things first. What are the symptons? What part of the program does the "Intake/Drain" flash?
Oct 28, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
How to clean intake & drain, light is on and
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jul 18, 2010 | Miele G848I Dishwasher
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Drain is clogged
I had a flashing red Intake/Drain light. After calling Miele tech support, he confirmed that the drain was plugged so I took all drain hoses apart and finally discovered that the problem was a plugged air gap. I replaced it and the problem was solved.
Nov 18, 2009 | Miele Dishwashers
Miele intake light on since new sink,disposal installed
check and see if the disposer drain port plug was removed. intake/drain light means slow drain or no drain
Feb 04, 2009 | Miele Touchtronic G892 Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Dec 16, 2007 | Miele Touchtronic W1113 Washing Machine
Miele Inspira Series Dishwasher w/ 6 Programs and 5 Temperatures - G2120 / G2120BL - Blac 24 in. Built-in Dishwasher Logo
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
