Question about Vacuums
I need to dismantle an electrolux el8501b vacuum to replace a lower hose how does the top come off??
    Sergeant:
    Champion:
  • Vacuums Expert
  • 357 Answers
It doesn't. The handle is part of the hose assembly
Posted on Oct 21, 2013
4 Suggested Answers
  • 15 Answers
SOURCE: vacuum hose replace electrolux how to
YOU DON'T SAY IF YOU HAVE THE NEWER HOSE OR THE CLASSIC ONE WITH THE STEEL TIP (BETTER DESIGN). IF IT'S THE LATTER UN-SCREW THE SCREW CLOSEST TO THE STEEL TIP,TAKE A SMALL SCREW DRIVER AND LIFT THE THE PIECE OF PLASTIC THAT WAS SCREWED DOWN JUST ENOUGH TO SLIP THE HOSE OUT.
WHAT YOU'LL BE FACED WITH IS SOMETHING I WOULDN'T SUGGEST CUTTING.
IT MAY BE MORE PRACTICAL BUYING A NEW HOSE. AN ELECTROLUX WILL LAST FOREVER,BUT YOU DO HAVE TO REPLACE THINGS LIKE THE COMBO DUST/UPHULSTRY ATTACHMENT. THE HOSE IS PROBABLY THE FIRST THING YOU WOULD NEED TO REPLACE BECAUSE OF AIR LEAKS. I'VE HAD MY OLYMPIA ONE FOR 27 YEARS AND HAD TO REPLACE THE HOSE ABOUT 10 YEARS AGO. YOUR CHOICE.
Posted on Dec 02, 2007
  • 15 Answers
SOURCE: Electrolux Epic 8000
YES,JUST TAKE OFF THE HEPA FILTER.
IF I MAY SUGGEST,IF YOU WANT TO BUY AN AREUS/ELECTROLUX YOU MAY WANT TO LOOK AT THEIR "BOTTOM OF THE LINE" MACHINE, THE "CLASSIC" IT'S HALF THE PRICE AND A MUCH BETTER DESIGN THEN THE NEW "FLAGSHIP" MODEL, WHICH IS COMPLETELY DIFFERENT THAN ANY PAST ELECTROLUX. IT'S BULKY,AWKWARD TO USE. EVEN IF YOUR BUYING FROM ANOTHER SOURCE, GO INTO AN AERUS DEALER AND GIVE THEM A TEST DRIVE.
I CLEAN APARTMENTS FOR A LIVING AND AM VERY FAMILIAR WITH ALL ELECTROLUX MODELS.
GOOD LUCK!
Posted on Apr 09, 2008
  • 73 Answers
SOURCE: Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
Posted on Aug 27, 2009
Electrolux el 7020 Canister Vacuum shuts of continuously do i need to Change the Carbon Brushes
How old? If fairly new you should not need brushes, bad brushes would probably not allow the vacuum to run at all. Last time you changed filter? Sounds like the cover to the filter is not closing well enough. There's also possibility you have a clog in the wand or hose.
Mar 05, 2015 | Electrolux EL7020 Bagged Canister Vacuum
My electrolux Epic won't stay running but it runs when the hose is off.
Check for a clog in the hose or most likely the vacuum valve on top needs removed for cleaning or replacing. Hope that helps!
May 13, 2014 | Electrolux Epic 6500 Vacuum
I need the Manual for #2100 Electroluks vacc
Service manuals for the Electrolux vacuums, including the accessories, are only available to the franchise owners and service techs.
Also, having said that, I don't recommend fixing the switch yourself. Replacing the switch involves disassembly of the canister, which is a bit complicated. Putting it back together correctly, without crimping wires. even more so.
I used to be an Electrolux service manager and have seen vacs brought in in pieces. Customers had succeeded in dismantling the machine, but were unable to reassemble it. Or had cracked or broken a piece. This makes the repair more expensive.
Or machines were brought it that had been reassembled incorrectly and wouldn't work. Or worse had shorted out due to crimped or incorrect wiring.
I strongly suggest taking the vacuum to a repair shop that is familiar with the older Electrolux vacuums, in this case the plastic models.
Mar 06, 2014 | Electrolux hose 2100 series diplomat
I have an Elextrolux Discovery Advantage(upright) . I need to replace the lower hose. Unfortunately the hose comes out of the roller/feeder area fine but I believe it is held in with a screw in the...
It's simply screwed into the tank. Simply unscrew in a clock-wise direction to remove. To install the new hose, screw in in a counter-clockwise direction. This is opposite the direction normally used for regular screws.
You don't need to dismantle the tank at all.
Nov 03, 2010 | Electrolux Vacuums
How do I gain access to the motor of an Electrolux 2000 canister vacuum. The air intake on the motor must be partially blocked as there is a loss of suction and the motor makes that high pitched whine like...
Dismantling the vacuum probably won't help much, and reassembling can be a bear.
To check the intake, remove bag and look into bottom of bag well. It there's a filter there, remove it and check intake at bottom of bag well. Clear if there is.
The afterfilter on a canister is located beneath the air diffuser grid on the top of the machine where the tools can be attached. Remove this cover and there should be a white filter. Yours is probably black, or at least real dirty, if it's never been changed. This also blocks the airflow, reducing suction, and potentially damaging the motor. Extremely dirty filters are an indicator of how much dust is getting into and through the motor. This is usually caused by using generic bags rather than the genuine Electrolux, now Aerus, bags.
It is also an indicator of another internal problem on some other Aerus and pre-Aerus Electrolux vacuums.
Sep 10, 2010 | Electrolux UltraLux 2000 Bagged Canister...
How do I fit a new duct lower motor cover?
Have a look at www.dysonmedic.com which has some very useful info on dismantling and repairing Dysons.
Mar 25, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
When running the 2100 Electrolux vacuum, it is stopping and starting when pulling or pushing the floor attachment. Seems like the connection at the top of the handle is a little loose or the electric tabs...
Depending on the age of your 2100, you will need to replace, the wand cord, the handle wiring and perhaps theh upper wand inner tube and handle as well.
If you examine your cord contacts they will be blackened from slippage, so will the female socket they plug into. On and aging 2100 the 1/2 inch groove at the front of the chrome handle tube begins to wear and the metal inner tube clip under the thumb button of the wand develops play back and forth. The wand comes apart into 4 pieces, plastic sheath, upper and lower tubes and cord assy.
If the hose handle groove is worn enough to allow in and out play, you will need to replace the handle, it's wiring, and at least the clip button on the upper wand as well as the wand cord.
You will find these wand parts at a pro vacuum shop but if your hose is original you will need to go to an AERUS Electrolux repair center for parts.
Post back with your results.
Nov 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
How do you replace short suction hose inside casing
This portion rarely needs replacing. It is designed to pull easily away from the brush side in case of blockage and then may need to "unscrew" use only the identical component form an AERUS Electrolux dealer. This should be accomplished without dismantling the head.
If there is evidence of glue or contact cement type adhesive on the bag side, you may need to tear apart and unravel with pliers
Nov 04, 2009 | Electrolux Epic 3500 Vacuum
We inherited an ancient canister Electrolux. There's plenty of suction with the hose out, but almost none when the hose is in. The hose is clear, and I can see no holes. What could the trouble be?
If it is an older fabric braided hose, which I expect it is, the rubber inside has been dried out for the last number of years. A great test is put the machine end of the hose in the blower side of the vacuum, under the little door on top. Spray the hose with windex or some other window cleaner, and cover the open end of the hose with your hand, turn on the vacuum, there will be bubbles all over the hose, this demonstrates how leaky the hose really is.
This is like trying to drink through a straw that has a hole in it.....does not work very well.
Do not under any circumstances buy another fabric type hose (USED) it will be just as leaky as yours.
The newer hoses are vinyl and last much longer. Also in most all cases when you replace the hose on these older electroluxs' they will clean as well as when new.....
Call most any vac shop they will have replacement hoses.
Jul 26, 2009 | Electrolux Guardian Bagged Canister Vacuum
Mar 10, 2009 | Electrolux Epic 6500 Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
