Question about Staples ID Armor SH2836ID2836 Shredder
Won't turn off after shredding in automatic mode
  • Suzanne Jones
    Suzanne Jones Oct 27, 2013
    When set to automatic shred, it never stops shredding when the paper has all gone into the bin. Keeps running. Can't leave it on Automatic. Have to turn it off & on manually.
  • Suzanne Jones
    Suzanne Jones Dec 04, 2013
    I tried this, thick cardboard in center only, no jammed paper visible to use tweezers on, soaking with WD-40 also no go. Still won't shut off automatically. I think I have to take it apart? Really really need it.
  • 221 Answers
This means that sensor located in the middle of feed opening has been jammed in down position. To clear this sensor arm you can try shredding strip of thick cardboard, but running it through in the very centre of the feed opening. Failing that clear the jammed paper using tweezers in addition to that you could soak the blockage between rollers with WD-40 or some lubricant. Give it a good soak, once paper softened and loosened complete clearing jam with tweezers. Your unit will operate like a dream!! Good luck
Posted on Nov 04, 2013
How do I put it into automatic mode?
Turn it on and set it to shred. It will start to shred when it detects paper fed into he slot.
Apr 21, 2015 | Office Equipment & Supplies
How do I put Staples SPL-770M into automatic mode?
Turn it on and insert a piece of paper you want to shred.
Apr 21, 2015 | Staples Office Equipment & Supplies
Unit won't turn off automatically
There could be a shred of paper blocking the sensor. It is good, and necessary, preventive maintenance to clean the shredding mechanism regularly to remove trapped paper.
Apr 24, 2014 | Fellowes Powershred C-320C Shredder
Won t shut off
Blow out the sensors with some compressed air, Using a can of compressed air, look for the sensors that detect the paper and give them a blast or two, then try it, it may take a couple of tries.
This may also be a good time to lubricate the cutting heads, if it is a good machine with metal heads a light oil applied to paper then run through the shredder will pass the oil onto the heads.
A shredder oil or light oil like 3 in 1, these usually have a narrow nozzle to limit the oil flow, draw lines, do a picture or spell your name on the paper with oil and shred it. You have just serviced your shredder.
If it is a less expensive shredder with plastic heads, shredding a couple if sheets of waxed paper will pass the wax onto the cutting heads reducing friction.
Hope this helps.
Ed
Oct 01, 2013 | Office Equipment & Supplies
Fellowes S8-95C is full, but can't get it open. Help!
I was able to pull really hard and open the bin 1-2". I turned the unit on its side over the trash can and some shreds came out. I alternated shoving a sturdy metal rod inside (first an aluminum architectural ruler then the longer handle of a squeeze clamp) to loosen up the shreds and tipping the machine on its side to get some loose shreds out. After doing this enough times I was able to dislodge the dense clumps and remove the drawer. Now that the machine is empty there is a red light on and it does not shred.....UPDATE: turns out somewhere along this rough process (paper was in rock solid clumps) a small piece of the door that presses the "door closed" switch broke off. Jammed a piece of cardboard in there and it shreds again, although it does not automatically turn off when the door is open.
Jun 30, 2011 | Fellowes SB95C Cross-Cut Shredder
Staples SPL-X21G shredder won't turn off
Blow canned air down into the feed slot.
Sep 22, 2009 | Office Equipment & Supplies
Motor not shutting off in Fellowes Powerhouse C-14 shredder
this is an issue with your paperfeed sensor. You need to call Fellowes at 1-800-945-4545.
Dec 18, 2007 | Office Equipment & Supplies
Automatic Shredding
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Dec 10, 2007 | Quartet gbc Shredmaster 2240S (Strip-Cut)...
Staples ID Armor SH2836ID2836 Shredder Logo
135 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
