Question about Avnex AV Video Karaoke Maker
Tarneeb 41 serial - Avnex AV Video Karaoke Maker
Year of manufacture of this gun?
Need make and model as well and the serial number
Google
smith and wesson model 41 serial numbers
and you will end up here
  • S&W Model 41 serial number search - Smith & Wesson Forum smith-wessonforum.com > ... > Smith & Wesson Semi-Auto
    • 35 POSTS
    • FIRST POST: 2012-01-05
    2016-01-18 · Hi everyone....I am looking at a S&W Model 41 22 lr. I`m interested in finding out what year it was made in. The serial number is UAV1XXX. is there a ...
  • Model 41 .22 LR Need Help to Determine Year of Manufacture www.smithandwessonforums.com/forum/s-w-semi-auto-pistols-forum/...
    • 9 POSTS
    • FIRST POST: 2011-08-14
    2013-09-30 · model 41 serial numbers, s&w model 41 serial number dates, s&w model 41 serial numbers, smith & wesson model 41 serial numbers, smith and wesson model 41 ...
  • http://www.bing.com/search?q=smith+and+wesson+model+41+serial+numbers&qs=n&form=QBRE&pq=smith+and+wesson+model+41+serial+numbers&sc=1-40&sp=-1&sk=&cvid=2E13F1737AF242EB90CE478CC92D51DD
    May 23, 2016 | Sport & Outdoor - Others
    Harley trouble codes
    There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
    1 Current 53 ECM flash error
    2 Historic 53 ECM flash error
    3 Current 54 ECM EEPROM error
    4 Historic 54 ECM EEPROM error
    5 Current 63 ECM serial data low
    6 Current 63 ECM serial data open/high
    7 Current 63 TSSM serial data low
    8 Current 63 TSSM serial data open/high
    9 Current 61 Loss of TSM/TSSM serial data
    10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
    11 Current 33 System relay contacts open
    12 Current 33 System relay coil high/shorted
    13 Current 33 System relay coil open/low
    14 Current 33 System relay contacts closed
    15 Current 99 Incorrect password
    16 Current 99 Missing password
    17 Current 41 CKP sensor intermittent
    18 Current 41 CKP sensor synch error
    19 Current 11 TP sensor open/low
    20 Current 11 TP sensor high
    21 Current 12 MAP sensor open/low
    22 Current 12 MAP sensor high
    23 Current 14 ET sensor voltage low
    24 Current 14 ET sensor open/high
    25 Current 15 IAT sensor voltage low
    26 Current 15 IAT sensor open/high
    27 Current 24 Front ignition coil open/low
    28 Current 25 Rear ignition coil open/low
    29 Current 24 Front ignition coil high/shorted
    30 Current 25 Rear ignition coil high/shorted
    31 Current 24 Front cylinder combustion intermittent
    32 Current 25 Rear cylinder combustion intermittent
    33 Current 23 Front injector open/low
    34 Current 32 Rear injector open/low
    35 Current 23 Front injector high
    36 Current 32 Rear injector high
    37 Current 16 Battery voltage low
    38 Current 16 Battery voltage high
    39 Current 43 VSS sensor low
    40 Current 43 VSS sensor high
    41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
    42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
    43 Current 35 Tachometer low
    44 Current 35 Tachometer high
    45 Current 25 Rear cylinder no combustion
    46 Current 24 Front cylinder no combustion
    47 Current 34 Loss of idle speed control IDLE AIR CONTROL
    48 Current 35 Accelerometer fault
    49 Current 34 Starter output high
    50 Current 25 Ignition enable output high
    51 Current 21 Left turn output fault
    52 Current 22 Right turn output fault
    53 Current 11 Battery voltage high
    54 Current 31 Alarm output low
    55 Current 32 Alarm output high
    56 Current 41 Ignition switch open/low
    57 Historic 63 ECM serial data low
    58 Historic 63 ECM serial data open/high
    59 Historic 63 TSSM serial data low
    60 Historic 63 TSSM serial data open/high
    61 Historic 61 Loss of TSM/TSSM serial data
    62 Historic 14 Loss of all ECM serial data (state of health)
    63 Historic 33 System relay contacts open
    64 Historic 33 System relay coil high/shorted
    65 Historic 33 System relay coil open/low
    66 Historic 33 System relay contacts closed
    67 Historic 99 Incorrect password
    68 Historic 99 Missing password
    69 Historic 41 CKP sensor intermittent
    70 Historic 41 CKP sensor synch error
    71 Historic 11 TP sensor open/low
    72 Historic 11 TP sensor high
    73 Historic 12 MAP sensor open/low
    74 Historic 12 MAP sensor high
    75 Historic 14 ET sensor voltage low
    76 Historic 14 ET sensor open/high
    77 Historic 15 IAT sensor voltage low
    78 Historic 15 IAT sensor open/high
    79 Historic 24 Front ignition coil open/low
    80 Historic 25 Rear ignition coil open/low
    81 Historic 24 Front ignition coil high/shorted
    82 Historic 25 Rear ignition coil high/shorted
    83 Historic 24 Front cylinder combustion intermittent
    84 Historic 25 Rear cylinder combustion intermittent
    85 Historic 23 Front injector open/low
    86 Historic 32 Rear injector open/low
    87 Historic 23 Front injector high
    88 Historic 32 Rear injector high
    89 Historic 16 Battery voltage low
    90 Historic 16 Battery voltage high
    91 Historic 43 VSS sensor low
    92 Historic 43 VSS sensor high
    93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
    94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
    95 Historic 35 Tachometer low
    96 Historic 35 Tachometer high
    97 Historic 25 Rear cylinder no combustion
    98 Historic 24 Front cylinder no combustion
    99 Historic 34 Loss of idle speed control
    100 Historic 35 Accelerometer fault
    101 Historic 34 Starter output high
    102 Historic 25 Ignition enable output high
    103 Historic 21 Left turn output fault
    104 Historic 22 Right turn output fault
    105 Historic 11 Battery voltage high
    106 Historic 31 Alarm output low
    107 Historic 32 Alarm output high
    108 Historic 41 Ignition switch open/low
    Aug 11, 2014 | 2000 Harley Davidson FLHRCI Road King...
    Kotcheena Games Tarneeb 41
    What exactly is your issue, your title and description of your problem is not clear.
    Oct 19, 2013 | Kotcheena Games Tarneeb 41
    Serial number
    This website is not intended to provide serial numbers for software products. It is against its terms of use.
    Master collection serial
    Serial No. 1045-1090-6246-8353-3166-2968
    Activation no.4583-2059-5989-1495-5412-3430-4063
    Activation Type : Normal: 159:41
    Please let me know Authorization Code...?.. please ..please...
    Sep 01, 2013 | Adobe Computers & Internet
    Pc free download
    Maybe look on "The Pirate Bay", but it is illegal to download games for free, which are sold for money.
    May 28, 2013 | Kotcheena Games Tarneeb 41
    What's your problem?Yalla Tarneeb
    ing, Please place ALL my chips back in my ACCOUNT. I need an answer, I just purchased 750K chips, played Poker and was up to 1million 500K and DDC upruptly closed me down, This happened over two times while I had a good hand to win. I am without my 750K that I purchased plus the 1million I had won in the Poker I was play
    Nov 08, 2012 | Tarneeb Ultimate Tarneeb
    I cannot log in to yalla tarneeb on facebook.
    this happens same to mee just download it again and you can log in to ttarneeb on fb
    Sep 26, 2012 | Tarneeb Ultimate Tarneeb
    Computers & Internet Logo
    332 people viewed this question
    Top Avnex Computers & Internet Experts
    David Payne
    David Payne
    Are you an Avnex Computer and Internet Expert? Answer questions, earn points and help others
