Question about Garden
How to stop the cutting attachment from turning while trying to start my Ryobi RLT26
    Sergeant:
  • 340 Answers
Dave you cant stop the head spinning as its attached to a spindle that goes through to the engine
Posted on Oct 14, 2013
Is there a fuse or a reset button on a Ryobi 10 inch surface planer. My planer stopped working after getting too hot. Now, it won't even trn on....
check the motor for a thermal over load button
to stop it over heating take more lighter cuts as the motor is a small motor compared to what the cut can be
May 09, 2016 | Ryobi Planer. 15 Amp 13 in. Planer AP1301
Ryobi problems
Sorry not to have better news. The plastic housing on that trimmer is not strong enough to support the drive gears. Ryobi has discontinued that model.
I have had mine apart several times. The housing for the gear cogs is plastic and flexes. I've tried to reinforce it and added spacers between the plastic housing and the bearings that support the drive shafts in attempt to force the teeth together. But the trick only lasts for a few minutes. As soon as I start to cut with it, it stops again. It's just not worth the time, effort and frustration to continue working on it just to have it stop working again.
I finally discarded the Ryobi unit and purchased one with a metal (aluminum) housing. I think it is a Poulan Pro model from Walmart. It has worked well.
Jul 07, 2014 | Homelite Expand-It Hedge Trimmer...
Ryobi rbs3080 motor stops when using
Try to install new blades. I've used 201 Haltbar blades in cutting pine before. Please get the right TPI too. But you may want to check the belt if it's slipping and try a slower feed rate.
Feb 27, 2013 | Ryobi Saws
Ryobi petrol line trimmer keeps on stopping
RLT26HT
the HT just means you have a hedgetrimmer attachment with it
the machine itself is a rlt26cds
remove your exhaust check the piston and the rings are not stuck
if piston is ok
then i would say it was either your carb need tightening and retuning
but not to tight or you will crack your bakerlite manifold
once you have done that
you will need a special carb adjusting tool (we call it the packman tool) if you remember the game packman thats what it looks like
at the end
the carb settings are screw all the way in do not over tighten the screws
and 2 turns out on both the screws
the screw nearest to the engine is your low revs
the outside screw is your high revs (you adjust this at full throttle)
this should get you started
if it still cuts out then it is your lead wire
that goes from your ignition module to the plug under neath you machine
hope this helps
regards
neil
Nov 19, 2012 | Ryobi Garden
I need a manual for Ryobi HT20VSK
The multi tool has no "chuck", it uses collets to fix the bits to the tool. Once the knurled cap is loosened or removed, the collet and bit can be removed. If the cap has been overtightened or left in the tool for an extended time, you can remove it by gripping the shank with pliers or vise grip and turn it to release the collet and bit.
Dec 29, 2011 | Ryobi Drills
My ryobi pbc-3046YE brushcutter wont run. When I start with choke it races for a few seconds then cuts out, if I get it started without choke it idles briefly then cuts out, if I try to accelerate it cuts...
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 09, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 25cc grass timmer, cuts out when full throttle applied
Are you running a gas/oil mix? If you are try making sure you didnt add too much oil (will usually smoke) and will possibly stall. Your air fuel mixture may be off and need adjusting too.
Aug 17, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Jun 13, 2009 | Ryobi Garden
Engine/shaft stopped working. Need to fix Ryobi trimmer.
Hi, I have a Ryobi brush cutter and the engine has a tendency to move up and down the shaft. It also rotates around the shaft
May 16, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
