Question about Vacuums
I need to replace a lower hose on an electrolux el8105b
    Sergeant:
    Champion:
  • Vacuums Expert
  • 357 Answers
Most parts for these are NLA. It wasn't a very good cleaner to begin with. It would save you some trouble to start over with a new vac.
Posted on Oct 21, 2013
Electrolux EL7055 powerhead not working
Have you tried testing the continuity in the hose, wand, and power nozzle? You can also try putting the hose directly in to the power nozzle. If you still need help with you electrolux vacuum try contacting evacuumstore.com
Nov 17, 2013 | Vacuums
I have an Elextrolux Discovery Advantage(upright) . I need to replace the lower hose. Unfortunately the hose comes out of the roller/feeder area fine but I believe it is held in with a screw in the...
It's simply screwed into the tank. Simply unscrew in a clock-wise direction to remove. To install the new hose, screw in in a counter-clockwise direction. This is opposite the direction normally used for regular screws.
You don't need to dismantle the tank at all.
Nov 03, 2010 | Electrolux Vacuums
Have electrolux renaisance e10 hose will not turn
This machine is sold only by a Electrolux dealer. Only they can get you the correct hose part. But you are right, it sounds like you have a bad electrical connection in this hose. That has been common.
Dec 03, 2009 | Electrolux Vacuums
How do I attache the hose on an Electrolux Epic Cannister vacuum and have it lock into place?
If you are having trouble hooking the hose to the machine, your latch is mostlikely broken. This can be replaced. You can either buy the latch at your Aerus/Electrolux shop and replace it yourself if you are mechanical or have the service manager do it for you. There shouldn't be very much of a charge for this simple process.
If you are talking about hooking the hose to the wands, there is a latch that will need to be replaced. If so, the best thing to do is have the service manager replace the latch because there are wires in the hose handle that are sometimes hard to deal with.
Joe
Nov 22, 2009 | Electrolux Epic 6500 Vacuum
When running the 2100 Electrolux vacuum, it is stopping and starting when pulling or pushing the floor attachment. Seems like the connection at the top of the handle is a little loose or the electric tabs...
Depending on the age of your 2100, you will need to replace, the wand cord, the handle wiring and perhaps theh upper wand inner tube and handle as well.
If you examine your cord contacts they will be blackened from slippage, so will the female socket they plug into. On and aging 2100 the 1/2 inch groove at the front of the chrome handle tube begins to wear and the metal inner tube clip under the thumb button of the wand develops play back and forth. The wand comes apart into 4 pieces, plastic sheath, upper and lower tubes and cord assy.
If the hose handle groove is worn enough to allow in and out play, you will need to replace the handle, it's wiring, and at least the clip button on the upper wand as well as the wand cord.
You will find these wand parts at a pro vacuum shop but if your hose is original you will need to go to an AERUS Electrolux repair center for parts.
Post back with your results.
Nov 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
We inherited an ancient canister Electrolux. There's plenty of suction with the hose out, but almost none when the hose is in. The hose is clear, and I can see no holes. What could the trouble be?
If it is an older fabric braided hose, which I expect it is, the rubber inside has been dried out for the last number of years. A great test is put the machine end of the hose in the blower side of the vacuum, under the little door on top. Spray the hose with windex or some other window cleaner, and cover the open end of the hose with your hand, turn on the vacuum, there will be bubbles all over the hose, this demonstrates how leaky the hose really is.
This is like trying to drink through a straw that has a hole in it.....does not work very well.
Do not under any circumstances buy another fabric type hose (USED) it will be just as leaky as yours.
The newer hoses are vinyl and last much longer. Also in most all cases when you replace the hose on these older electroluxs' they will clean as well as when new.....
Call most any vac shop they will have replacement hoses.
Jul 26, 2009 | Electrolux Guardian Bagged Canister Vacuum
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
Jan 21, 2009 | Electrolux Central Vacuum
Vacuum hose replace electrolux how to
YOU DON'T SAY IF YOU HAVE THE NEWER HOSE OR THE CLASSIC ONE WITH THE STEEL TIP (BETTER DESIGN). IF IT'S THE LATTER UN-SCREW THE SCREW CLOSEST TO THE STEEL TIP,TAKE A SMALL SCREW DRIVER AND LIFT THE THE PIECE OF PLASTIC THAT WAS SCREWED DOWN JUST ENOUGH TO SLIP THE HOSE OUT.
WHAT YOU'LL BE FACED WITH IS SOMETHING I WOULDN'T SUGGEST CUTTING.
IT MAY BE MORE PRACTICAL BUYING A NEW HOSE. AN ELECTROLUX WILL LAST FOREVER,BUT YOU DO HAVE TO REPLACE THINGS LIKE THE COMBO DUST/UPHULSTRY ATTACHMENT. THE HOSE IS PROBABLY THE FIRST THING YOU WOULD NEED TO REPLACE BECAUSE OF AIR LEAKS. I'VE HAD MY OLYMPIA ONE FOR 27 YEARS AND HAD TO REPLACE THE HOSE ABOUT 10 YEARS AGO. YOUR CHOICE.
Nov 08, 2007 | Electrolux Centralux Vacuum
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
