Question about Vehicle Parts & Accessories
Removing door handle drivers side mk1 mini - Vehicle Parts & Accessories
    Problem Solver:
  • 17 Answers
It takes real small hands, and lots of patiences
Posted on Oct 14, 2013
Removing.passenger door on a 02ford ka?
I have never done one of these but ....
Here is a thread
Door removal Interior Exterior Ka Mk1
... and a You tube vid... showing driver door but it helpful in reverse.
Ka Door Card Removal
Hope this helps, good luck!
Oct 04, 2016 | Ford Ka Cars & Trucks
Removing front drivers side door panel, cant seperate at door handle.
MIGHT BE TWO SCREWS ON BOTTOM SIDE OF HANDLE! IF SO, THERE WILL BE TWO ROUND COVERS OVER THEM
Feb 20, 2011 | 2004 Suzuki Forenza
How to fix driver's side door to 1995 chevy silverodo the handle's broke I usually have to lock from outside
open the cover by using screw driver. after removing the screws remove the cover then you can replace the defective part of your door handle cable or the handle
May 14, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Driver side handle replacement
in most vehicles, replacing the handle entails removing the inside of the door to access the mechanisms inside. there usually isn't a way around this. a repair manual can assist with directions on how to go about doing this type of project.
Apr 28, 2010 | 1999 GMC Suburban
Driver side door doesn't unlock from the inside
Remove door panel check all fitings corrsion, lube with anti electric grease.
Sep 11, 2009 | 2005 Mini Cooper
Need to replace drivers side door handle?
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. If it's the inside handle, you'll need to disconnect the rod from the back of the handle. If it's the outside handle, you'll need to pull back the weather seal and use a socket wrench (10mm or 11mm I believe) and remove the mini bolts holding the outer handle on, be careful as I believe the lock cylinder is also held on by the same bolts. then you should be able to pop off the handle (disconnect the rod first)
Aug 21, 2009 | 1991 Chevrolet S-10
How do you remove the drivers side door handle on a 2000 GMC pick
Hi those are somtimes a pain ,I,m not sure which part your at on your job but once you release the linkage that is attached inside your door panel then you should be able to remove the nuts or screws that hold the door handle in from the inside then when you get the handle out from the truck then remove the lock ,also put some masking tape around the paint on the outside of the door ,because when remove the handle from the door and putting it back in you may have to angle the handle a bit for it to fit back into place ,sometimes a long pick with a 45degree tip on it helps alot when removing the inside linkage ,hope this helps ,let me know if I can help further!
Aug 08, 2009 | 1999 Chevrolet Silverado 1500
Installing exterior driver side and passaner side door handles
I found this on another page, hope it helps:)
Remove the plastic cover behind the door handle assembly by removing one black 14mm nut from just above the door handle, and 1 screw (usually phillips) from the bottom of the plastic cover.
Remove linkages from lock cylinder and door handle assembly. Use a small flathead screwdriver to slide retaining clips forward, and linkages will come free.
Remove one black 14mm nut from the very top of the door handle assembly.
Remove one phillips screw drom the bottom of the door handle assembly.
Door handle assembly should now come free by pulling out slightly at the top, and pulling upwards.
Transfer lock cylinder and key minder light (if applicable) to new door handle assembly. Lock cylinder is retained by a single TORX bolt.
Reinstall in reverse.
TIP: If you lose or damage any of those black plastic coated nuts, order new ones. They are GM p/n 10067214 and should be around $0.58/each. There are two on each door.
Mar 02, 2009 | 1995 Pontiac Grand Prix
2000 lx 470 driver door panel
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
Oct 11, 2008 | 2000 Lexus LX470
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
