Question about Hammering
Need serpentine belt diagram for 2006 chrysler sebring with 2.4l
Mike258
  • 1498 Answers
SOURCE: serpentine belt came off
Here's how to get a serpentine belt on or off (You'll need to do both). It's easy and doesn't require a prybar. The routing is usually diagrammed on a label under the hood.
On:
  • Get a 14mm or 9/16" socket and a long handled ratchet or breaker bar.
  • Get the belt around all the pulleys except the A/C compressor or Alternator.
  • Locate the tensioner pulley. It's one of the smaller ones and is mounted on a spring loaded arm. It's job, as the name suggests, is to keep the belt tight. Get your socket on the center nut of this pulley.
  • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt on the final pulley.
  • Slowly release the tension.
  • You're done
Off:
  • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt off one of the pulley's (A/C or Alternator is best)
  • You're done
Mike
Posted on Aug 15, 2009
  • 1168 Answers
SOURCE: need serpentine belt routing for 2006 chrysler
Hello Damon104.
The best way to help you with this question is to give you this site.
Dayco belts offers this and covers most makes and models.
www.mvreader.com/multiview/dayco/index.php?bgInterchange=1&l=n
I hope your repair goes well for you.
Kl
Posted on Dec 17, 2009
motor1258
  • 6674 Answers
SOURCE: need a diagram or routing picture for serpentine
Posted on Jan 10, 2010
  • 239 Answers
SOURCE: need a diagram for serpentine belt for a 1996
On the underside of the hood (sometimes on the radiator shroud) there should be a decal showing the routing of the belt for the enging that came in the car originally.
Posted on Jan 16, 2010
  • 538 Answers
SOURCE: 2007 chrysler sebring serpentine belt diagram
Go to; daycoproducts.com, click cars and trucks, then go to serpentine belt. Then on the right side of the screen click on finding your vehicle. Then get the illistration number and click on illistrations, go to that number it should something 6-? or 7-?. It's a pretty good websight.
Posted on Jan 31, 2010
Belt routing for 2001 Sebring 2.4 engine
Jeff, Check the attached links for your 2.4 belt routing,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Repair Guides Engine Mechanical Components Accessory Drive Belts 2...
How to Change Serpentine Belt on 2002 Chrysler Sebring
http://www.serpentinebeltdiagram.com/serpentine-belt-diagram-2001-chrysler-sebring-4-cylinder-24-liter-engine-alternator-and-air-conditioner-with-dohc-engine-02236
Jul 31, 2016 | Cars & Trucks
2.4L NOT 2.7
follow this link , should help and will get additional advice
2003 Chrysler Sebring Serpentine Belt Routing and Timing Belt Diagrams
Jun 01, 2014 | 2004 Chrysler Sebring
Ho is the power steering belt on 2002 chrysler
Click on the following direct Link. It has the Belt Diagrams you will need, complete with Removal Diagrams and Directions. It also has numerous other helpful diagrams for use.
Standard Rules to Removal the Serpentine Belt with a Tensioner:
1. Find the Tensioner(s). (See Diagrams on Link)
2. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
3. Remove the loosened belt off one of the other more easily accessed Pulleys.
4. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
Standard Rules for Installing the Serpentine Belt with Tensioners:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
http://www.2carpros.com/car_repair_information/year/2002/make/chrysler/model/sebring/2002_chrysler_sebring_drive_belt_routing_diagram.htm
Mar 25, 2010 | 2002 Chrysler Sebring
2006 Chrysler Pacifica serpentine belt routing
here are a couple diagrams...
If you need anything else, let me know.
Mar 15, 2010 | 2006 Chrysler Pacifica
Jan 31, 2010 | 2007 Chrysler Sebring Sedan
Need a diagram for serpentine belt for a 1996 chrysler sebring convertable
Jan 16, 2010 | 1996 Chrysler Sebring
I need a diagram for a 20007 sebring alternator
I need help on reinstalling a Serpentine Belt back onto a 2007 Chrysler sebring
Jan 05, 2010 | 2007 Chrysler Sebring Sedan
Need serpentine belt routing for 2006 chrysler sebring 2.4l engine please
Hello Damon104.
Kl
Dec 17, 2009 | 2006 Chrysler Sebring
Hammering Logo
44 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
