Question about Hunter 44905 H Univ. 7 Day Thermostat
My hunter 44905 thermostat beeps constantly what does that mean
    Top Expert:
  • Hunter Master
  • 34,704 Answers
Could be needing battery replacement
Posted on Oct 13, 2013
Testimonial: "put new battery in still beeps cant make it stop"
Refresh mode not working
Thermostat is either wrong one or not wired right
Aug 27, 2014 | Hunter 44905 H Univ. 7 Day Thermostat
Why won't thermostat turn on after I changed the batteries?
I think you may have the model # incorrect, However if you have a thermostat as in the type that are hand held, polarity of the batteries is the 1st thing I would check, then test them for proper voltage, corrosion will often interrupt that small of a voltage, clean the terminals and test it .
A wall mounted like a central HVAC system typically will not require batteries to operate, this is for memory and they will work fine even if no batteries are installed, however there are battery powered stats too, meaning non parasitic type that not powered by the transformer in the air handler.
I will include a basic drawing of a residential HVAC thermostat to show you how the 24 volts powers most thermostats.
ome > Air Filtration > Air Cleaners and Purifiers > Hunter Air Purifiers > Hunter 30124 HEPAtech 124 Air Purifier w/ Ionizer Hunter 30124 HEPAtech 124 Air Purifier w/ Ionizer
Item #: hun30124 892f1d0d-b50f-49aa-8079-70d2dc34eb2b.png
Jun 07, 2014 | Hunter 30124 Air Conditioner
I have a goodman cplj30 heat pump and I'm trying to install a hunter 44905 thermostat but I'm not I have it wired correctly. The wiring is as follows. R to R Y to Y G to G O to O W and E...
The Y, G, O and C are correct, the W and E are not tied together.
The W is the main cal for heat and should be wired into the heat pump reversing valve wire, usually blue but you need to check. E goes to to E and is for emergency heat, I.E. it turns on your furnace when it gets too cold for the heat pump to keep up.
The t-stat operation in heat goes like this:
T-stat calls for stage one heat via the W terminal, if after a few minutes the temp does not start to rise the t-stat call s for backup heating via the E terminal, this turns on your furnace or heat strips in your air handler if you have electric heat.
Jun 14, 2011 | Heating & Cooling
Blinking re co on thermostat
It means that you are going into from one program to another program.
Jul 15, 2009 | Hunter Fan Company 5/1/1 Programmable...
Programmable Thermostat Model 43157
On my Hunter model, there is a "Span" setting that allows you to change how long the AC/Heat will run before it turns off. Basically, it sets the acceptable range (above and below) your temperature setting. To access this press both the up and down arrows and hold them. "Span" should show up with a number (1,2, or 3). For your problem, change the setting to 1 so the AC will run shorter, and more frequently to keep the temperature more constant.
Aug 29, 2008 | Hunter Fan Company 5/1/1 Programmable...
Thermostat
By resetting I found out that there was low battery, but now I can't get the face of the thermostat off to put in a new battery. Manual got displaced.
Jul 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter thermostat need manual
Hi
u can fine your manual here...
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
Gary
Feb 28, 2008 | Computers & Internet
Flashing re co
Re Co stands for Recovery Mode. That means if you have programed your thermostat to be at say 72° at 5:00 then it should kick on in Recovery Mode several minutes before 5 in order to reach that temperature. This is normal and doesn't indicate that something is wrong, just that your thermostat is trying to reach or recover the programed temperature.
Feb 08, 2008 | Heating & Cooling
Hunter 44905 H Univ. 7 Day Thermostat Logo
105 people viewed this question
Top Hunter Heating & Cooling Experts
Jay Finke
Jay Finke
Mack Baxter
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
